Thread: Aircon problem?
  1. Aircon problem?
    Jan 2016
    West Lothian
    14 Post(s)
    Think the aircon has broken something on our Passat B8 estate. Started making a whining noise the other day. Took it out for a run and if you turn the aircon to low it sounds like Dyson vacuum. Also doesn’t seem to be cooling that well and the condensation was noticeable. Had the air con serviced last year.
    Any thoughts? Compressor?
    Is it likely to be expensive?
    VW Passat GT 4 Motion 2.0 BiTdi, '16MY in Midnight Blue, keyless entry, memory seats, active info display and Discover Nav Pro
    Audi A7 20MY Vorsprung 3.0tdi in Daytona grey, with optional rear cup holders! (Previously A7 16my S Line)
  2. Re: Aircon problem?
    Jan 2016
    Winchester Hants
    29 Post(s)
    The aircon is a black hole for money because it can be a number of things.
    My son's Skoda Octavia (most probably similar, if not same parts, as VW) went TU. Gave car to an AirCon specialist who did the evaluation....either compressor, this that or tother. 6 weeks later, everything attached to the engine replaced and £1300 he got the car back 'fixed'. The following day it went TU again. I did some DEEEEEEPPPP Googling...a £5 control panel switch module off ebay fixed it. Which would most probably have fixed it with the old parts.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  3. Re: Aircon problem?
    Jan 2016
    West Lothian
    14 Post(s)
    Thanks. Hopefully it will be the cheap part
    Going to get it booked into the VW dealer where the aircon was last serviced
  4. Re: Aircon problem?
    Jan 2016
    Winchester Hants
    29 Post(s)
    Their quote will be most interesting.
  5. Re: Aircon problem?
    Jan 2016
    West Lothian
    14 Post(s)
    Garage couldn’t find an obvious fault. Re-gassed system and put dye in so a trace can be conducted if it happens again. No charge
  1. aircon problem
    By masterinengland in forum Touran - Sharan - Caravelle
    Last Post: 10-10-2013, 09:44 PM
  2. Another Aircon problem
    By BeaBea in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-07-2013, 07:30 PM
  3. Aircon problem!
    By kromal1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2011, 04:51 PM
  4. aircon problem
    By audistormer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2009, 07:18 PM
  5. Aircon problem
    By Cal in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2006, 10:48 PM
