Thread: Oval crank pulley BKD engine
  1. Oval crank pulley BKD engine
    Oct 2018
    York
    9 Post(s)
    I gather (from Crasher) that the oval crank pulley on these engines is not that common....does this mean that I need a different cambelt than the round-pulley motors? I've counted the teeth on the installed belt (141, same as other BKDs), but I'm wondering what difference the oval pulley makes to any other parts required - coolant pump, tensioners, idlers etc. I don't have the VIN or VRM from the donor car, just the engine.
    Anyone any ideas?
  2. Re: Oval crank pulley BKD engine
    1837 Post(s)
    The only difference is the tool used
  3. Re: Oval crank pulley BKD engine
    Oct 2018
    York
    9 Post(s)
    Ok cheers Crasher. The correct tool should be here today or tomorrow.
    Do you know the reason for having the oval pulley...and why it apparently wasn't common?
  4. Re: Oval crank pulley BKD engine
    1837 Post(s)
    The 038 105 263 F pulley was only used up until mid 2006 production and the upper pulley is the same as normal but interestingly the damper behind it isn't so damper 03G 109 239 B must be used with the oval pulley. Probably they later discovered no one could tell the difference.
  5. Re: Oval crank pulley BKD engine
    Oct 2018
    York
    9 Post(s)
    Interesting, thanks for that Crasher. Although (it seems to me, anyway) that the slight 'relaxation of the drive belt' would have instantly been compensated, or adjusted, for by the cambelt tensioner. I wonder if this constant repeated stress on the tensioner resulted in more breakages - either of the tensioner, or the tensioner stud? Or maybe my logic is a bit off, dunno.
  1. Crank pulley failure
    By B5NUT in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-09-2023, 11:14 AM
  2. A6 C7 Crank Pulley Failed! :(
    By Sheroo in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-06-2021, 01:28 PM
  3. 3.0 tdi Crank pulley
    By G18EWS in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-03-2015, 12:38 AM
  4. Crank shaft pulley
    By morgans in forum Alhambra
    Last Post: 24-04-2010, 10:22 PM
  5. crank pulley
    By dangerousdog in forum The Commercial Range
    Last Post: 02-11-2008, 04:10 AM
