Thread: 2014 Audi A8L won't start
  1. Angry 2014 Audi A8L won't start
    Jul 2020
    Santa Cruz, California, USA
    Ok, I'm fairly mechanically minded but the technology of these later models has me baffled. This A8L lights up, everything appears to come on but will not turn over, not a sound, no clicks, nothing.  Battery is fine, have tried the key in and out, checked out the fuses and all look good, ran the ODBII and got some O2 stuff but nothing that I think should prevent it from at least cranking.  I ran a CAN-bus (auto detect) old Ross-Tech VCDS (version 17.1) and other than the O2's there were no DTC codes that should prevent it turning over. And I cleared ALL codes too. I'm stumped...any advice?
  2. Re: 2014 Audi A8L won't start
    Oct 2019
    Peterborough, England
    23 Post(s)
    Hi!
    what is the battery output? If it is lower than 11.9 ? Volts, then it won’t even try.
    have you recently changed the battery? If so, did you tell the Energy Manager and give it the new battery codes?
  1. Audi A7 2014 plate, MMI
    By frog61 in forum A7 - S7
    Last Post: 17-09-2016, 12:40 PM
  2. SD Card and new 2014 Audi A4
    By Camerashy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-03-2015, 12:24 PM
  3. Question Audi S3 Sportback 2014
    By Kbradan in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 28-02-2015, 06:15 PM
  4. 2014 Audi A6 Prestige
    By mjrdoc in forum New Member Introductions
    Last Post: 16-04-2014, 08:45 PM
  5. Audi A6 2014 - Re-Badging
    By mgsaudi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-01-2014, 01:46 PM
