Thread: golf 1.9tdi bxe coolant issue
Results 1 to 10 of 10
  1. golf 1.9tdi bxe coolant issue
    May 2020
    Pontyclun
    I sorted the electrical issue but now i thought i had a temp gauge issue.
    Turns out the lower half of the rad is not getting hot.
    My first thoughts are stubborn airlock or stuck thremostat.
    I replaced the thermostat but exactly the same.
    Surely i can't have an air lock in exactly the same place? The rad was new but has run hot before this strip down.
    So as not to cook the motor i'm going to remove the 'stat tomorrow.
    Any ideas? are these notoriously stubborn to rid an airlock?
    There is no blockage as i've filled the rad with hot water and it runs throughout
  2. Re: golf 1.9tdi bxe coolant issue
    Feb 2020
    Bradford
    39 Post(s)
    Quote Originally Posted by dean.st View Post
    These are meant to be vacuum filled and can often be problematic if coolant is not vacuum filled.
    Do remind what the symptoms were and what engine and what you have already tried like squeezing the hoses etc. If I recall correctly you had low temps showing with no overheating on a bxe?
  3. Re: golf 1.9tdi bxe coolant issue
    May 2020
    Pontyclun
    It took me the best part of 2 hours this morning to get the coolant to fully circulate and remove the air bubbles. I was not buying a vac kit.
    Now although the engine is hot throughout, the rad fan isn't kicking in and the coolant temp gauge takes forever to get just a 1/4 way up. It sits normally at 1/2 way (90). I also have the coolant symbol flashing on the info screen even though the water level is fine.
    There is power to the fan at the plug.
  4. Re: golf 1.9tdi bxe coolant issue
    May 2020
    Pontyclun
    I've just run power straight to the fan and no action. However there is a green wire and a black wire (which i assume is the trigger wires from the sensors?) do i need to bridge either of these to the 12v live to get motion in the fan?
  5. Re: golf 1.9tdi bxe coolant issue
    Feb 2020
    Bradford
    39 Post(s)
    It'll be digital signal controlled by the ecu. Output test with vcds may be easier
  6. Re: golf 1.9tdi bxe coolant issue
    108 Post(s)
    1816 Post(s)
    Yes the main fan is the controller and is commanded by a LIN BUS signal from the engine ECU
  7. Re: golf 1.9tdi bxe coolant issue
    Feb 2021
    My coolant is not properly circulating after a water pump/timing belt replacement. What did you do to get it to fully circulate and remove the air bubbles?
  8. Re: golf 1.9tdi bxe coolant issue
    108 Post(s)
    1816 Post(s)
    Can you find out which make of pump was fitted?
  9. Re: golf 1.9tdi bxe coolant issue
    Feb 2021
    It was a eurocarparts pump, I’m not sure which one as my mechanic purchased it but I could find out.
  10. Re: golf 1.9tdi bxe coolant issue
    108 Post(s)
    1816 Post(s)
    It could provide a clue, we only fit genuine pumps and cam belt kits for peace of mind, well in theory as mine started leaking after a year and there was no way I was following the TPS warranty procedure and taking it to Skoda for some spotty trainee oik to break.
  1. Golf mk5 1.9tdi miss fire issue
    By Orange Triffid in forum Golf MK5 - 2004 - 2009
    Last Post: 14-12-2015, 04:05 PM
  2. Please Help Toledo 1.9tdi 110 heater and coolant issue
    By steve320cd in forum Toledo
    Last Post: 21-10-2015, 02:43 PM
  3. Replies: 4
    Last Post: 01-06-2013, 03:49 PM
  4. Golf Mk3, 1.9TDI Wipers issue!
    By Sparky6975 in forum Golf MK3 - 1993 - 1999
    Last Post: 29-06-2011, 08:52 PM
  5. engine coolant capacity golf 1.9tdi sport
    By ccs in forum Golf MK5 - 2004 - 2009
    Last Post: 01-09-2010, 10:46 PM
