Thread: Issue with LED Daylight running light (Pics)
  1. Issue with LED Daylight running light (Pics)
    Jun 2020
    Southport
    As promised, here's an issue I spotted yesterday.
    One of the DRLs seems to be a lot dimmer than it should be, also as you can see below it's got a yellow hugh to it. I put photos of both sides for reference.
    Any ideas what could be wrong/possible fix?
    Thanks in advance for any input.
  2. Re: Issue with LED Daylight running light (Pics)
    Feb 2014
    Cork, Ireland
    This is usually an age/usage related issue and often blamed on overheating/warm climates.
    It’s starting to appear randomly on 2010 - 2013 Audi models.
    Fix usually means a replacement headlamp which will be €€€, hope you’ve got warranty as you’ve just bought the car.
    Great spec by the way and welcome to the forum.
  3. Re: Issue with LED Daylight running light (Pics)
    Jun 2020
    Southport
    Quote Originally Posted by Joe2.0E View Post
    Thanks for the info, a bit of an odd one but would tie in with being in a warm climate.
    No warranty so I'll wait and see if a headlamp comes up 'cheap' in the usual places. For now it's something I can live with. Luckily the rest of the unit works normally.
  4. Re: Issue with LED Daylight running light (Pics)
    Oct 2018
    Maputo
    I have dealed with this problem on a Q7 of a friend.
    If you disassemble the headlamp you will find that the tube that reflects the LED and makes that shape ( there are 4 LED's ) is burned from heat of the LED.
    So the yellow color is just burned/melted plastic were the LED sits. usually it burns and makes a small hole.
    What I have done, was cleaning it and polish, its not easy... but it gets better
    Another thing, The outerside LED are easier to work, the ones on the Inside (your case) are very difficult to reach and repair.
    I have some photos of the previous and after the job, if you want I can show.
    Here in Mozambique the DRL its not on the law, so if you want you can Code to turn them on/off on the MMI...
  5. Re: Issue with LED Daylight running light (Pics)
    Jun 2020
    Southport
    Thanks for taking the time to reply, quite an interesting thing to happen.
    I know if I attempted the fix you did I would end up doing more bad than good so I will leave it for now!
  1. Daylight Running Lights
    By mikegbingham in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-11-2014, 04:46 PM
  2. Question Daylight running light help?
    By arabianjules in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-10-2014, 04:27 PM
  3. Xenon light retrofit led daylight running ?!?!
    By Tristan77 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-08-2013, 07:35 AM
  4. LED Daylight Running Lights
    By Stonkn in forum Audi A3 - Archive Topics
    Last Post: 18-12-2007, 12:49 PM
  5. Daylight Running Lights
    By happy2bhere in forum Passat - Archive Topics
    Last Post: 30-11-2006, 10:19 AM
