Thread: Removal Of Door Panel
  1. Talking Removal Of Door Panel
    Aug 2007
    Hi there,
    I have a 2001 A6 Avant, unfortunately It looks as though I have to remove my door panel, but I am unsure of the process. There would probably be loads of hidden screws and clips which I dont want to break. Has anyone removed a panel before and got any advice ?? Ideally pictures would be ideal but text will do.
    Many thanks
  2. Re: Removal Of Door Panel
    1 scre at the top front and 1 screw at the top rear. Then lift up and out. Then you'll see the cables etc you'll need to disconnect. Job done.
  3. Re: Removal Of Door Panel
    Aug 2007
    Many thanks for your reply.
    I removed the two screws and tried to remove the panel, but it is not moving. It feals that it is secured at the bottom aswell. I tried leavering with a screwdriver but had to stop as I thought the panel would snap. I applied as much pressure as I thought it could handle. There defininately is no other hidden screws ????
  4. Re: Removal Of Door Panel
    hmmm, there could be a couple under the door - have a look. But mine just has the 2 and with a bump under the bottom it pops up and off
  5. Re: Removal Of Door Panel
    May 2007
    There are only two screws, like Nial says. There are some hooks at the bottom, you should be able to lift them away.
  6. Re: Removal Of Door Panel
    AJO Guest
    I can also confirm there is only two screws.... you must lift it though!
  7. Re: Removal Of Door Panel
    Aug 2007
    Nice one, thanks guy's. Have managed to get the door panel off.
    Once again many thanks,
    Matt
  1. Knocking in side door/ door panel removal
    By AudiwantisanS3 in forum Audi A3 - Archive Topics
    Last Post: 04-03-2008, 06:06 PM
  2. Door panel removal instructions
    By Toni in forum Touran - Sharan - Caravelle
    Last Post: 24-08-2007, 08:10 AM
  3. S4 front door panel removal
    By Lovnangel1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-07-2007, 07:33 PM
  4. Door panel removal - help??
    By DeeVee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-07-2006, 03:45 PM
