Thread: Particulate filter identification.
Results 1 to 10 of 10
  1. Particulate filter identification.
    Jun 2019
    Please forgive my ignorance. I have a 2014 Audi A6 Avant TDI Ultra, with a 1968cc engine. I need to replace the bank 1 particulate filter. Is there any way of knowing the part number of the correct filter, without physically inspecting the vehicle? I am not a mechanic, and there are possibly one or two used filters available on ebay - at much less than the horrendous prices of new ones - even though it has a lower life expectancy than a new one it could be worth it! The vin code is wauzzz465EN203711. Many thanks!
  2. Re: Particulate filter identification.
    Aberdeen
    53 Post(s)
    Are you sure you need a new one? Crasher (garage owner and moderator on this forum) sends some away to get professionally cleaned. Might be worth getting in touch with him. He can probably give you the correct part number too.
  3. Re: Particulate filter identification.
    Jun 2019
    Thanks, Scott. I am not sure what the problem is. Local specialists (here, in Portugal) have failed to identify the problem or rectify it, despite my having spent time and money trying to get it fixed. This desperation time! I will contact Crasher.
  4. Re: Particulate filter identification.
    Mar 2014
    Aylesbury Bucks
    13 Post(s)
    What are the symptoms of the problem, and have you got a scan of all the ECUs with the fault codes?
  5. Re: Particulate filter identification.
    Jun 2019
    I have has a range of problems and fault codes. This has led to a 1000 mile cutoff, system fault messages, blocked particulate filter, and more. It has been going on (with Audi garages and others involved) and various components being changed. The latest, which has been displayed before, is P 2002. I can clear it, but it comes back after perhaps 100 miles. So this really is an elimination exercise - if I change the filter and the fault is still there, I will know to look somewhere else, which is why I am keen to get a second hand one, but do need to know the correct part number. Some people have said that there is nothing wrong with the filter; others have said it needs changing. I am using good fuel.
  6. Re: Particulate filter identification.
    39 Post(s)
    891 Post(s)
    Thank you for including your VIN, if I had my way it would be a required part of every new thread started as it is not GDPR data. HOWEVER, the data is wrong, it should be WAUZZZ4G5EN203711
    The original DPF was 04L 131 601 T but has now changed to 04L 131 670 SX which is 1375 UK retail.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  7. Re: Particulate filter identification.
    Jun 2019
    Thank you for this excellent help. I shall purhase one from a low-mileage car (25000km) and see how it goes!
  8. Re: Particulate filter identification.
    Jun 2019
    Quick update. I have now purchased the filter so usefully identified (thanks again) from a 27k vehicle, for €309 including carriage, being sent from Germany and arriving in a week or two. Once it has arrived and fitted I will see how it goes - you may see a new thread from me if the fault code returns!
  9. Re: Particulate filter identification.
    Jun 2019
    A quick further question! When the ‘new’ DPF arrives and is fitted, is it worth replacing anything else at the same time as a precaution (so preventing duplicated workshop fitting costs)? I don’t know how big a job the fitting would be. Thanks.
  10. Re: Particulate filter identification.
    Feb 2016
    Blaydon, North east England
    50 Post(s)
    I'd be tempted to have the new DPF professionally cleaned before installation, it'll help make sure its not blocked or be full of contaminants.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  1. particulate filter
    By ismart in forum Passat - B8 Forum - 2015 -
    Last Post: 13-04-2017, 10:56 AM
  2. Particulate Filter Warning
    By andyhud007 in forum Q7 - 4M Forum - 2016 -
    Last Post: 20-02-2017, 11:14 PM
  3. A5 3.0 tdi particulate filter
    By Kyledavis in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 04-12-2015, 09:17 PM
  4. diesel particulate filter
    By barryn466 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-05-2011, 10:20 AM
  5. Question Particulate Filter
    By Conrad83 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-06-2009, 01:21 PM
