Thread: Front passenger window switch not working
  1. Front passenger window switch not working
    Jun 2020
    Leeds, UK
    Hi all,
    Wonder if someone would be kind enough to help? The front passenger window switch is not working. The window can be controlled from the drivers side. I've checked the window lock and it's not that. Problem started after some idiot pocket pressed the unlock button on fob and left windows open overnight in rain! Is the problem likely to be the passenger window switch or something more serious?
    Any help much appreciated.
    Jon
  2. Re: Front passenger window switch not working
    Sep 2009
    Stoke on Trent, England
    11 Post(s)
    How long is a piece of string?
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Front passenger window switch not working
    Jun 2020
    Leeds, UK
    Thanks Keithuk
  1. Window switch, aircon, recirculation, demister switch and parking sensor not working
    By masterinengland in forum Touran - Sharan - Caravelle
    Last Post: 18-10-2015, 08:14 PM
  2. Passenger Window Switch
    By mrb333 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-05-2013, 10:55 AM
  3. A3 2007 : Front Passenger Window Not Working
    By Steve-T in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-10-2011, 07:37 PM
  4. Passenger side electric window switch
    By rapport25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2010, 11:53 AM
  5. Replies: 1
    Last Post: 25-05-2009, 10:52 AM
