Thread: What would cause a drive belt to fail like this?
  1. What would cause a drive belt to fail like this?
    Jan 2020
    Bristol
    This was changed around 30,000 miles ago at the same time as the cambelt and water pump. I heard this strange noise while driving yesterday that sounded like a loud flapping that got louder with revs (but silent on idle). Before I could pull over safely it had stopped and I thought maybe a plastic bag had got stuck under the car and carried on driving for a few miles. When I went out again later the battery light was on so I turned around and went home. The drive/auxiliary/serpentine (or whatever it's called) belt was shredded and off its pulleys.
    Does anyone know what I should be looking out for that could have caused this before I get it replaced? The alternator pulley seems to spin fine but I didn't have time to try anything else (the rest is pretty hard to get to from above). Cheers.
    (2012 Passat B7 TDI 130 saloon by the way).
  2. Re: What would cause a drive belt to fail like this?
    1840 Post(s)
    I would say the alternator one way clutch is seized, the way to test this is spin the alternator and grab the pulley to stop it, the internals of the alternator should carry on for a moment.
  3. Re: What would cause a drive belt to fail like this?
    Jan 2020
    Bristol
    Cheers for the tip. I've been reading that I can jam the alternator with a screwdriver, then try to turn the pulley both ways and it should turn anticlockwise but not clockwise. If it turns both ways (or won't turn either way) then it's bust. Sound about right?
  4. Re: What would cause a drive belt to fail like this?
    1840 Post(s)
    Yes, more counter hold than jam and use a nonconductive tool or disconnect the battery.
  1. Bkd engine help timing belt fail
    By AAGT150 in forum Golf MK5 - 2004 - 2009
    Last Post: 31-03-2019, 06:32 AM
  2. A4 B7 Air conditioning compressor - FAIL - Poss fail - Maybe fail - Has Failed
    By blackgrill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-05-2012, 02:36 PM
  3. Changing the timing belt and drive belt on Audi A6
    By Robbromilow in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2009, 08:00 PM
  4. drive belt / fan belt problem!
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2008, 06:17 PM
  5. Aux drive belt on 1.8T
    By GavinT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2007, 12:47 AM
