Thread: Cruise control/lost gears /over rev issue
  1. Cruise control/lost gears /over rev issue
    Jun 2020
    Oxfordshire
    Hi All.
    I hope someone can help me diagnose some symptoms... Car is 2013 Mk6 golf estate TDI.
    1. Whilst in cruise control, in 5th gear, the cruise control drops out when the incline increases.
    2. When in 5th gear the display says I'm in 3rd sometimes 4th.
    3. General drive - when road inclines the speed drops off quickly even when pressing accelerator peddle.
    4. General drive - engine initially feels like it's pulling in gear, any gear, then the feeling of drive stops and revs increase.
    I have recently changed the battery, if this helps any.
    Any help would be much appreciated prior to me going to a garage.
    Many thanks and kindest regards
    Ross
  2. Re: Cruise control/lost gears /over rev issue
    1836 Post(s)
    I thought the gear indicator suggested rather than indicated the gear? Start with a code read.
  3. Re: Cruise control/lost gears /over rev issue
    Jun 2020
    Oxfordshire
    Thanks for the response.. I don't have a code reader that works as it turns out!
    Have taken it to a garage who have confirmed it is the clutch.
    FYI the gear indicator does not use sensors, it's a direct reading of speed hence erratic gear reading when clutch was slipping....
    Regards
    Ross
  1. Cruise Control Issue after bump in road
    By jbanfie in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 27-12-2012, 06:40 PM
  2. Cruise control wind turbulence issue
    By Sailorf80 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 14-11-2011, 02:33 PM
  3. Cruise Control Query - Manual Gears
    By simfin in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-01-2011, 10:43 PM
  4. Question 04MY A8 Cruise Control Issue
    By lukeylogic in forum A8 - S8 - V8
    Last Post: 01-11-2009, 10:03 PM
  5. Cruise Control Temporary Issue
    By forge197 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-11-2008, 10:29 PM
