Thread: Engine management light and glow plug light errors/fault codes
Results 1 to 10 of 12
  1. Engine management light and glow plug light errors/fault codes
    Jun 2019
    I have a VW golf 2009 2.0tsi 140hp with a CBAB engine. My car has been going in to limp mode continuosly and was told by my breakdown company that the intake manifold actuator is faulty. Upon doing research I noted I had the error code P2015 to which I bought the add on to the actuator however this hasn't worked.
    I managed to get hold of the diagnostic kit for VW Audi and ran it myself. I have attached the fault codes below. I believe the main culprit which is causing the limp mode is the MAP sensor however I can seem to locate it for the engine. It also mentions O2 sensor, intake manifold bank 1 position and power steering controls module.
    If anyone can give feed back to any of the fault codes and how to get these all fixed that would be great. It is my daily work horse and I need it up and running asap.
    Sent from my ONEPLUS A5010 using Tapatalk
  2. Re: Engine management light and glow plug light errors/fault codes
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The intake manifold flap valve is a common cause of problems.
    Oil & crud run down from the EGR which discharges just above this valve.
    It obstructs the flap & oil sometimes runs along the valve spindle into the electronics behind the plastic cover on the side, which shorts out the electronics.
    Either replace it, or if into DIY, remove it & clean it thoroughly.
    Remove the plastic side cover & if full of oil, clean it out with brake or contact cleaner including the electric motor.
    Check the plastic gears which if damaged will require a replacement valve.
    This valve might be responsible for some of the other codes, but obviously not the steering.
    Once replaced clear the codes & see what returns.
  3. Re: Engine management light and glow plug light errors/fault codes
    Jun 2019
    Thanks for the comments.
    I had the intake manifold cleaned by one of my local garages and they also replaced the intake manifold actuator. The fault codes were removed and these are the fault codes that have appeared in my initial post.
  4. Re: Engine management light and glow plug light errors/fault codes
    Feb 2020
    Bradford
    40 Post(s)
    With the steering code check the bus bar power steering lead and connector at the front of the engine bay fusebox for corrosion.
    On mine, although no fault yet, the build up of crud corrosion was noticeabily higher on the power steering positive lead.
    Is the power steering fault permanent?
    Note tsi and tdi are different vw engines
  5. Re: Engine management light and glow plug light errors/fault codes
    Jun 2019
    I will check this tonight. Yes the steering module error is a permanent fault code, however it doesn't seem to affect anything that I can see.
    My main concern is the limp mode which I understand is the MAP sensor (correct me if I'm wrong), however I don't know the location on the engine. I have rung VW and they mentioned the MAP sensor isn't sold separately as it comes within another unit? So they will want to diagnose it themselves which is way too expensive for me.
    I want to know if anyone has replaced the MAP sensor for the 2.0 TDI CBAB engine? I know where the lambda sensor is however I think this might be a fault code caused by the intake manifold and MAP sensor so I don't want to spend the money on this until I'm certain it is.
  6. Re: Engine management light and glow plug light errors/fault codes
    Jan 2009
    Birmingham
    35 Post(s)
    1 - 5 Nm
    2 - Mounting
    q For charge air cooler.
    3 - Charge air cooler
    q To remove, bring lock carrier into service position → General body repairs, exterior; Rep. gr.50.
    4 - Connecting hose
    q »Cold« side, bottom.
    5 - Screw-type clip, 5.5 Nm
    6 - To throttle valve module -J338-
    7 - Connecting hose
    q »Cold« side, top.
    8 - Charge air pressure sender -G31- with intake air temperature sender -G42-
    9 - 2 Nm
    10 - Rubber grommet
    q Renew if damaged.
    11 - 8 Nm
    12 - Charge air pipe
    q »Cold« side.
    13 - Connecting hose
    q »Hot« side, top.
    14 - From turbocharger
    15 - Charge air pipe
    q »Hot« side.
    16 - Connecting hose
    q »Hot« side, bottom.
    1 - 5 Nm
    HI ITEN NUMBER 8 IS THE G31 MAP SENSOR
  7. Re: Engine management light and glow plug light errors/fault codes
    Jun 2019
    Is that for CBAB engine? Looks as if it is difficult to reach and change.
  8. Re: Engine management light and glow plug light errors/fault codes
    Jan 2009
    Birmingham
    35 Post(s)
    Get it on a ramp. Have a look under it might be able to see
    part number for new sensor is 038906051c
  9. Re: Engine management light and glow plug light errors/fault codes
    Jan 2009
    Birmingham
    35 Post(s)
    looks like this
  10. Re: Engine management light and glow plug light errors/fault codes
    Jun 2019
    Thanks I will try and get a look at it this weekend.
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2020, 07:34 PM
  2. Please Help Glow Plug Light - ENGINE FAULT .. Temperamental ??
    By stusmalls1990 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-09-2018, 10:30 AM
  3. Glow plug & Engine Management Light
    By wheels2014 in forum A1
    Last Post: 26-08-2015, 01:16 PM
  4. 2.0tdi 170 intermittent glow plug light and Engine management light.
    By nigedvd in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 19-06-2014, 10:14 AM
  5. Question DPF, glow plug and engine management light all showing
    By patel321 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-09-2013, 06:35 PM
