Thread: towbar fitting a6 c7 saloon 2.0 sl electrics
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #21
    Jun 2020
    st helens
  2. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #22
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    The attachment 37109 link doesn't work. Is it set for public access? No need if it the same as the other link.
    Things like the "floating" fuse holders (rather than picking up positions 1-3 in the green standard holder) and relay (not used in OEM loom, as the 6mm cable to fuse box handles power load) make it look like a generic rather than OEM loom. Do you have something for A and B to plug into? Looks like there should be some control box or other.
  3. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #23
    Jun 2020
    st helens
    A plugs directly into the red male bit see below
    .... b nothing c nothing DE ? earth
  4. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #24
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Comparing your pictures to the diagrams in the PDFs yuo linked it looks quite like the first PF Jones one.
    Missing the extra loom at pic 17 (because they had red block like you, or it was used but leaving it behind was easiest for whoever removed it).
    Missing the control box for plug B at pic 25.
    Relay looks extra though, so not sure what's going on there. Maybe compare with generic kit to see if it has it?
  5. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #25
    Jun 2020
    st helens
    This one appears to have the relay https://www.pfjonesebay.co.uk/instructions/AU039D1U.pdf
    as it wasnt described as 3rd party i have two options send it back as not described or go to pf jones to see if they have the other bits and get them to code it?
    i have just found these other connectors Double ended as pictured.
  6. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #26
    Jun 2020
    st helens
  7. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #27
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    So you found those extra bits of loom already with you, but not the control box? Ask them if they can get it from the vehicle?
  8. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #28
    Jun 2020
    st helens
    i will ask...it was taken from scrap vehicle so it might not be about....pf jones could possibly supply one. or just buy full 13 pin kit all else fails what do you think? The extra bits bar control box had slipped out of sight under spare wheel......when i ran in yesterday due to heavy showers. So it looks like just missing a control box...
  9. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #29
    Jun 2020
    st helens
    also found ecs also have same kits with model number ECS Electronics | Towbar wiring kits © ECS Electronics B.V.Pag. 2
    AU-039-D1U / 261015TT
  10. Re: towbar fitting a6 c7 saloon 2.0 sl electrics
    #30
    Jun 2020
    st helens
    The journey to self install the wiring stops here sadly i cant buy the control box and the coder wont guarantee his work on a used loom.. best i can do is photograph the finished professional install.
  1. Please Help A4 Avant Towbar fitting - electrics problems
    By kevin191176 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-06-2017, 08:08 PM
  2. Does my '08 Jetta have a towbar electrics socket for dedicated electrics?
    By EdF in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 21-10-2013, 01:23 PM
  3. Fitting a towbar - electrics
    By pauldelaf in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-03-2011, 12:08 AM
  4. Fitting towbar electrics
    By caravaner in forum Golf MK6 - 2009 - 2013
    Last Post: 01-10-2009, 07:54 PM
  5. fitting a towbar to an A6 saloon?.....
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-06-2009, 10:39 PM
