Thread: Driveshaft replacement DIY ?
  1. Driveshaft replacement DIY ?
    Feb 2020
    Sweden
    I知 looking too replace my passengerside driveshaft by myself but i知 not 100% confident yet.
    I know my way around cars but you never know with Audis .
    So I looked up a clip on youtube and it seemed very simple,
    He took off tyre ofcourse.
    He broke loose the big nut 19mm allen.
    Removed plastic shield held by 2 M10 nuts.
    Loosened 6 torx from flange .
    And pulled the whole shaft inwards away from hub.
    Is that it ???
    My model is a non Quattro, s-tronic A5 2.0 tfsi
  2. Re: Driveshaft replacement DIY ?
    1840 Post(s)
    Could you private message me the cars VIN, there are a few different designs.
  3. Re: Driveshaft replacement DIY ?
    Feb 2020
    Sweden
    Ofcourse
  4. Re: Driveshaft replacement DIY ?
    1840 Post(s)
    That is supposed to come out just by disconnecting the inner and the outer bolt BUT the manual says that if it has a subframe shield you have to release the upper links which is a sketch. I have looked on ETKA with your VIN and you do not appear to have this shield. Remember all the bolts and nuts removed MUST be replaced and the torque procedure for the outer bolt is specific.
  5. Driveshaft replacement DIY ?
    Feb 2020
    Sweden
    Thx buddy !
    Time to get bussy I guess
  6. Re: Driveshaft replacement DIY ?
    Feb 2020
    Sweden
    I did have a shield, but still managed to take it out the easy way.
  1. Question needed: good replacement driveshaft brands and where to buy.
    By churp in forum Touran - Sharan - Caravelle
    Last Post: 04-05-2019, 01:27 PM
  2. Groning noise after driveshaft replacement -
    By Highline786 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-11-2014, 08:50 PM
  3. Audi 80 Driveshaft replacement
    By Phil Read in forum 80 - 90
    Last Post: 06-01-2009, 08:08 PM
  4. Driveshaft boot replacement
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-05-2007, 05:50 PM
  5. driveshaft replacement
    By gilroy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-12-2006, 07:11 PM
