Thread: Exhaust pressure sensor pipes
  1. Exhaust pressure sensor pipes
    Jun 2020
    Ringwood
    Hi, have recently added an A3 1.9 TDI to the group and in working through some hot start issues discovered the pipes for the Exhaust pressure sensor are cut/ missing. I can see the manifold is blanked off where one should attach, can’t really see the other without stripping parts out but wondered if this had been seen before and any reason to do this? Obviously the plan is to source the pipes etc and replace but could this cause hot start problems and a smokey exhaust?
  2. Re: Exhaust pressure sensor pipes
    1837 Post(s)
    Which year and engine type code?
  1. Exhaust Pressure Sensor
    By sarahegg in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-12-2019, 02:25 PM
  2. Question Fitting A New G450 Sensor (Exhaust Pressure Sensor)
    By VAG in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-05-2018, 02:16 PM
  3. Exhaust gas pressure sensor
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-01-2012, 10:37 AM
  4. Exhaust pressure sensor
    By DMitch16 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2012, 10:30 PM
  5. G450 exhaust pressure sensor
    By autobrake3 in forum Golf MK6 - 2009 - 2013
    Last Post: 26-09-2011, 09:28 PM
