Thread: Changing rear spring
Results 1 to 10 of 10
  1. Changing rear spring
    Dec 2013
    Liverpool
    10 Post(s)
    How easy / difficult is it to change the rear springs, got broken ones.
    2007 2.7 SE quattro saloon
  2. Re: Changing rear spring
    Feb 2015
    Peterborough
    7 Post(s)
    Just replaced my rear two, it’s a bit of a pain defo the worst springs I’ve ever changed(due to the design of the rear suspension). You will defo need some wishbone spring compressors as the standard type will not fit.
    2010 A6 TDI 170 S Line Avant
    Sold 2007 A3 TDI 170 S Line
    Sold - 2002 S3
  3. Re: Changing rear spring
    Dec 2013
    Liverpool
    10 Post(s)
    Are those the type that fit inside the spring (disk type) could you post a photo?
  4. Re: Changing rear spring
    Feb 2015
    Peterborough
    7 Post(s)
    FreeTec Wishbone Suspension Coil... 503 - Service Unavailable Error
    Sold - 2002 S3
  5. Re: Changing rear spring
    Feb 2015
    Peterborough
    7 Post(s)
    Yes like these ones on Amazon
    Sold - 2002 S3
  6. Re: Changing rear spring
    Feb 2015
    Peterborough
    7 Post(s)
    Sold - 2002 S3
  7. Re: Changing rear spring
    Dec 2013
    Liverpool
    10 Post(s)
  8. Re: Changing rear spring
    Dec 2013
    Liverpool
    10 Post(s)
    Anyone recommend a good brand for replacement coil springs for rear, Seen Sachs on ******* for a reasonable price.
  9. Re: Changing rear spring
    Feb 2015
    Peterborough
    7 Post(s)
    I used Febi Bilstein ones also sourced from *******. I’ve never had issues with Febi or Sachs so either are good choices.
    Sold - 2002 S3
  10. Re: Changing rear spring
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    I spent some time cross-checking docs like this Sachs catalogue with what the online suppliers had to make sure I was getting something close to OEM spec on the specific suspension set up, rather than something that fits but is quite generic: Asset download.
  1. A4 B6 Avant rear spring
    By mickel2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-01-2018, 10:33 AM
  2. Please Help Fault codes after changing clock spring
    By Jon_m in forum Altea
    Last Post: 19-07-2017, 11:35 AM
  3. rear spring has broke again
    By hunterczt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-07-2015, 01:35 PM
  4. How To rear air spring change
    By Ricmand in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-04-2015, 12:43 PM
  5. Rear Spring Snapped!
    By clouseau in forum Bora - 1998 - 2005
    Last Post: 30-05-2008, 08:10 PM
