Thread: Golf MK6 - Knocking in suspension
Results 1 to 10 of 13
  1. Golf MK6 - Knocking in suspension
    Feb 2019
    Manchester
    After replacing the broken coil spring i (left front), a strange sound appeared.
    Knocks are not always heard.
    Any idea?
    Below in zip file is record in mp4
    knocking_sound_01.zip
  2. Re: Golf MK6 - Knocking in suspension
    Feb 2020
    Bradford
    40 Post(s)
    Can't do rar files on phone. Be better if you post using one of the video sharing sites like youtube
  3. Re: Golf MK6 - Knocking in suspension
    Feb 2019
    Manchester
    I upload on YouTube:
  4. Re: Golf MK6 - Knocking in suspension
    Feb 2020
    Bradford
    40 Post(s)
    First thing to check is the upper connection on the anti roll bar link for looseness. The nut can become loose, joint can wear but it sounds more free then joint noise. Can be checked with road wheel still on the car turn fully inwards/outwards turn car off remove key, then grab a hold of the link and see if it has free play.
  5. Re: Golf MK6 - Knocking in suspension
    Feb 2019
    Manchester
    Hi, Thanks for reply.
    I check Anti roll bar and is solid.
    But, I check everything for any loose and I find something,
    When I get coil spring and try squeeze I hear exactly this noise. And fill like spring is moving, but in very barely palpable but palpable.
    And after one squeeze is no noise or movement, but when I jerked is back to position when I could squeeze and hear noise.
    Is feel like top mount of spring is not proper connected or putted and is some loose.
    I marked where I squeeze with one hand.
  6. Re: Golf MK6 - Knocking in suspension
    Feb 2020
    Bradford
    40 Post(s)
    Quote Originally Posted by goralpm View Post
    The strut top nut can work loose..but that will result in a squeek/judder/skipping motion whilst turning the steering wheel.
    Its possible the three bolts holding the strut bearing are loose.
    Both these items can be viewed under the black plastic trim
  7. Re: Golf MK6 - Knocking in suspension
    Feb 2019
    Manchester
    Quote Originally Posted by Roverfan View Post
    Sorry for delete, but I was very byssy.
    Ok.
    I check every connection. All bolts and nuts are nice and tidy.
    Other mechanic suggest it could be wrong coil spring.
    Still looking for some solution's.
  8. Re: Golf MK6 - Knocking in suspension
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    What spring did you use, from where? Did you do the heavy duty "upgrade" in the end after your queries last year?
  9. Re: Golf MK6 - Knocking in suspension
    Feb 2020
    Bradford
    40 Post(s)
    Ok.
    I also had the suspicion it was an incorrect coil spring.
    The best solution is get this booked into your local garage and get it fixed. You'll have your car back maybe within a few hours and be safe.
  10. Re: Golf MK6 - Knocking in suspension
    Feb 2019
    Manchester
    OK, one more update.
    I was today in garage (same), after 8h garage change Shock Absorber and charge me another £140...
    the mechanic said he should replace same time as coil spring, but... they just charge me another £47 for labour.
    What is strange, when he change coli spring he charge me 1,5h but now 1h... Anyway.
    So in couple of weeks I will be testing if everything is OK
  1. Knocking Suspension
    By TonyMc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2010, 04:27 PM
  2. a4 DTM suspension knocking
    By stu dtm in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-08-2009, 09:40 PM
  3. Knocking suspension
    By Lofty79 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-04-2008, 09:33 PM
  4. suspension knocking
    By simonvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2008, 10:38 PM
  5. Suspension knocking!!!
    By SRA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-06-2007, 09:11 PM
