Thread: Wiring info for rear wiper motor B6
  1. Wiring info for rear wiper motor B6
    Peterborough
    Hi all, I see there's load of stuff about changing wiper motors, but does anyone know what the plug connections should be reading in terms of voltage when intermittent is on. I've had my 51 plate 1.9 TDi for 18 years and determined to keep her going, quite a few things starting to fail now :-(.
    Changed motor back in 2013 and no problems till recently when it only worked when it felt like it. Bought a new motor but before taking the old one out connected the new one to the plug to test, guess what this didn't work either. So either I've a dodgy new unit or the wiper stalk / wiring has a problem.
    The voltage at the plug is 12+ve (Yellow/Black) 12-ve (Black), got nothing on the blue or brown cores, cant find a decent wiring diagram to help so any info would be greatly appreciated.
    TIA for any help, cheers
  2. Re: Wiring info for rear wiper motor B6
    Near Blackpool
    48 Post(s)
    If you have VCDS you can activate wipers via central Convenience module which would take the stalk out of the equation?
  3. Re: Wiring info for rear wiper motor B6
    Near Blackpool
    48 Post(s)
    May have my years mixed up but if it’s not controlled via the cc module then it would be on a relay. I did have the wiring diagrams somewhere but can’t seem to find them as sold the car years ago.
  4. Re: Wiring info for rear wiper motor B6
    Peterborough
    Quote Originally Posted by jonathanfenton View Post
    OK cheers, unfortunately I don't have a VCDS, I'll wait and see if anyone else has a drawing to hand or another suggestion. thanks for taking the time to reply its appreciated.
  5. Re: Wiring info for rear wiper motor B6
    Peterborough
    OK fault traced to broken cable near the RHS hinge, rubber gater opened to find the break, reconnected problem sorted. Hope this helps someone with a similar issue, now just need to make a watertight repair to the gator.
  6. Re: Wiring info for rear wiper motor B6
    Near Blackpool
    48 Post(s)
    Nice one.
  1. Rear wiper motor
    By bainbo1973 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-08-2015, 09:10 AM
  2. Rear wiper motor
    By coup80 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-11-2013, 09:55 PM
  3. rear wiper motor wiring
    By rich080487 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-10-2013, 11:14 AM
  4. Audi A3 "06 plate" rear wiper motor/wash wiring...?
    By premmington in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-12-2009, 06:27 PM
  5. Rear wiper motor
    By Paul123 in forum Alhambra
    Last Post: 06-05-2008, 07:05 PM
