Hi, i have attended a 2013 Audi A5 this afternoon that was just purchased by owner with supposed ABS module issue, i have scanned vehicle and as far as i can tell the vehicle has the incorrect steering assist module fitted, possible steering rack replacement.
before i commit to a new rack for customer i would appreciate a second opinion on shown fault.
ABS module is showing a incorrect coding issue as well, but this could relate to a incompatible steering assist module.
I have cleared all faults now and the only faults i get back are engine control module, ABS and steering assist.
this is the fault that i find most concerning.
4215041 - Control Module
C109F 00 [008] - Incorrect Version Installed
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 6
Reset counter: 54
Mileage: 238340 km
Date: 2020.06.16
Time: 14:12:34
Wednesday,17,June,2020,16:08:53:21447VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
Ross-Tech: Home
VIN: WAUZZZ8T7EA046651 License Plate: NU63
Mileage: 238340km-148097mi Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72
VIN: WAUZZZ8T7EA046651 Mileage: 238340km-148097miles
05-Acc/Start Auth. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JG HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2839
Revision: 45H25---
Coding: 0A194012232401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JG 003005
ROD: EV_ECM20TDI01103L906018JG.rod
VCID: 78FBA5B8C3808C4633-802C
2 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 238341 km
Date: 2020.06.17
Time: 16:01:36
Engine speed: 852.50 /min
Normed load value: 32.9 %
Vehicle speed: 0 km/h
Coolant temperature: 28 °C
Intake air temperature: 23 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.740 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): switch position-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 8
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 238341 km
Date: 2020.06.17
Time: 16:01:36
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Component: ESP8 front H09 0020
Revision: -------- Serial number: --------------
Coding: 16550C01
Shop #: WSC 06325 123 12345
VCID: 0719D644B67EF3BE4A-8052
1 Fault Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 238341 km
Time Indication: 0
Date: 2020.06.17
Time: 16:04:14
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0045
Hex Value: 0x09AD
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 JE HW: 8K0 907 064 JE
Component: BCM2 2.0 H14 0650
Revision: 00002001
Coding: 03B44040000000000000
Shop #: WSC 06325 000 00000
VCID: 7CF3B9A8FFB8A06657-8028
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0814000003743013
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2312000269328012
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 54
Mileage: 238340 km
Time Indication: 0
Date: 2020.06.16
Time: 13:55:59
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K2 820 043 AH HW: 8K2 820 043 AH
Component: KLIMA 3 ZONEN H04 0121
Revision: D0000000 Serial number: 01150120140609
Coding: 342402E000
VCID: 6FE99EE4BECECBFEE2-803A
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00000057215601
Coding: 260000108034AFC00081400000001D0D001D03082709020100 0008004400020100000024000000
VCID: 77F9A684C69E833E3A-8022
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 041213 H13 0080
Serial number: SWF13120045053
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22126532
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001912131369
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 080844E6000000000001
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H47 0610
Serial number: 003KFDB3LH0H
Coding: 30533938363030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 489B1578F3E03CC683-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME415D22178
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME410B150EA
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME363C505AL
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME2D3D094E-
Crash sensor for front airbag: driver side:
Serial number: 63732SME5B3B3F78J
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME3038067A.
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NAC000FN
Coding: 000016
VCID: 489B1578FBE03CC683-801C
Component: E221 - MFL H03 0004
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 54
Mileage: 238340 km
Time Indication: 0
Date: 2020.06.16
Time: 13:56:34
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 984 K HW: 8T0 920 984 K
Component: KOMBIINSTR. H35 0564
Revision: 00000000 Serial number: Z9H42JJDE
Coding: 33A5300002012600010000
VCID: 47991644F6FE33BE8A-8012
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y13C170F5F
Coding: 80CF07FF00
VCID: 4A9F2F70E5ECCED695-801E
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 1481372103
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 13225003551011200410
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 Q HW: 8T0 959 793 F
Component: TSG FA H09 0305
Coding: 011002624001450005
VCID: 57B9C604265EA33E1A-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0029547278
Coding: 010000010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 346351889F68A826DF-8060
3 Faults Found:
3158408 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 14
Mileage: 238340 km
Date: 2020.06.16
Time: 14:12:34
Write only channel
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 14
Mileage: 238340 km
Date: 2020.06.16
Time: 14:12:34
Write only channel
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 54
Mileage: 238340 km
Date: 2020.06.16
Time: 14:12:34
Write only channel
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0323561129
Coding: 013B0622A0B900408320043680000047
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 4
Reset counter: 54
Mileage: 238340 km
Time Indication: 0
Date: 2020.06.16
Time: 13:55:59
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813024164504
VCID: 2D5544EC7442F9EE90-8078
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 Q HW: 8T0 959 792 H
Component: TSG BF H08 0305
Coding: 011002224001450005
VCID: 56A7CB0021549A3601-8002
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 20000000382288
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 397D60BCB80A554E0C-806C
3 Faults Found:
460032 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 54
Mileage: 238340 km
Date: 2020.06.16
Time: 13:56:32
Voltage terminal 30: 12.8 V
Internal Fault ID: 141
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
460288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 54
Mileage: 238340 km
Date: 2020.06.16
Time: 13:56:32
Internal Fault ID: 142
RWU: not active
DSD: not active
HTR: not active
ECD: not active
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 54
Mileage: 238340 km
Date: 2020.06.16
Time: 13:56:32
Internal Fault ID: 185
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109AY0E7855620
Coding: 010103010000000001
VCID: 285BB5F85BA0DCC663-807C
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 666 E HW: 8R2 035 666 C
Component: H-BN-EU H47 0793
Revision: -------- Serial number: 206D10F7564568
Coding: 13010104000681ED01808B5E00000403E40000020000000000
Shop #: WSC 34307 001 1048576
VCID: 3B717AB4BA36675E1E-806E
Subsystem 1 - Part No: 8R0 060 884 BK
Component: EUR 2014 1703
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130LX0D2901187
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000001715056
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0305
Coding: 010002224001450005
VCID: 59BDC03C504AB54E2C-800C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0305
