Thread: A6 Rear Wash/Wipe arm going a little beserk
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: A6 Rear Wash/Wipe arm going a little beserk
    #21
    Jun 2013
    Norwich, UK
    Mine had similar symptoms and I replaced the motor last week. (Also ended up replacing the wiper arm because it had corroded itself to the motor shaft. I bought a pulling tool but still couldn't remove it without destroying it)
    Having read a few posts elsewhere and stripped the old one down I believe that the root cause (or at least contributory factor) of this problem is blocked washer jets. (Mine were blocked and extremely difficult to properly unblock because there must be an uneven internal profile which stops you poking the crap out. I would actually recommend replacing the jet at the same time).
    There is an internal seal which has to deal with the shaft motion and I suspect it wears with time. When the jets are blocked there is an increased pressure differential across the seal which allows washer fluid to enter the wiper gearbox. My mechanism was heavily rusted. There is also a small circuit board which controls the wiper motion and sometimes this can get flooded too. Either or both will cause erratic behaviour or failure.
  2. Re: A6 Rear Wash/Wipe arm going a little beserk
    #22
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by Norfolkchris View Post
    Thanks for this.
    It's an annoying problem. My jet (or at least the cap) is defo not blocked - whenever you activate the rear wiper, water floods out onto the screen with no problems at all.
    The other day, I did sit in it in my driveway, and use the rear washer for ages. I checked the boot afterwards, and there was no water hanging about in the tailgate. Yesterday, I could hear water swishing about as I opened the tailgate, so it seems likely that rainwater is finding it's way in, rather than it being a leak from the rear wiper system.
    Looking at the boot, it has been suggested that the seals behind the tailgate lights are the likely suspect. I will check this out when I get another motor and look to fit it. However, what I don't understand, is how this affects the electrics of the wiper motor in any event? The lights are a good deal lower than the wiper and wiper motor, therefore, even if rainwater is getting into the tailgate behind the lights, how can it possibly affect the wiper motor internals?
  3. Re: A6 Rear Wash/Wipe arm going a little beserk
    #23
    Jun 2013
    Norwich, UK
    Quote Originally Posted by rjsdavis View Post
    Thanks for this.
    I agree. I don't see how water entering low in the tailgate can affect the wiper motor at the top. I said above that I thought blocked jet were contributory to the internal water leak problem but I think the leak could still happen without this. When I took mine apart I could see that the seal relied on a rusting metal tube rotating inside a rubber seal - it's bound to leak to some extent. You can actually inspect it without removing the wiper or motor. After removing the tailgate trim panel the motor is exposed. You can unclip the washer hose and then remove 4 or 5 small screws that secure the cover plate. Take it off and it will immediately be clear whether you have a leak. All the steel moving parts inside mine were heavily rusted.
  4. Re: A6 Rear Wash/Wipe arm going a little beserk
    #24
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    How easy does the plastic boot trim come off? I have to swap my motor, that was blocked
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  5. Re: A6 Rear Wash/Wipe arm going a little beserk
    #25
    Jun 2013
    Norwich, UK
    Quote Originally Posted by dean warren View Post
    I'm not sure I would say easy but I followed the video below which is accurate. You need to pull pretty hard to release the clips. The hardest part is the last two plastic tabs which he points out in the video. You need to study the pictures carefully to understand the correct direction to pull to release them. It's hard to get a grip in the right place. In the end I bent a small hook on the end of a piece of stiff wire and slid it between the glass and the trim so I could get a strong pull in the right direction. Just take it slowly and understand which way it wants to move to avoid breaking anything.
    YouTube
  1. No rear wash wipe
    By Not_Anumber in forum A7 - S7
    Last Post: 26-03-2020, 08:52 AM
  2. Rear wash wipe
    By katie68 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-08-2011, 09:47 AM
  3. Please Help rear wash/wipe
    By martin59 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-10-2010, 11:58 AM
  4. Please Help How do I get to the rear wash wipe
    By awake 502 in forum Audi A3 - Archive Topics
    Last Post: 20-01-2009, 05:39 PM
  5. Please Help Rear Wash Wipe
    By leonardj in forum Audi A3 - Archive Topics
    Last Post: 09-08-2008, 10:06 AM
