Thread: Wheel bolts.
Results 1 to 10 of 14
  1. Wheel bolts.
    Mar 2007
    Sunderland
    Hi everyone, I have a 2012 Q5 with a space master spare wheel but I also have a space saver (already inflated) which I would prefer to carry. Trying this on the car I found that the original wheel bolts are not long enough. Can anyone tell me what length and taper I need to use. Thanks in advance.
  2. Re: Wheel bolts.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Is there a part number on the inflated space saver? Standard Q5 bolts look to be 45mm long, but not listed for a space saver (except the collapsing one).
  3. Re: Wheel bolts.
    Mar 2007
    Sunderland
    I will check in the morning and let you know. Space saver was bought brand new(not by me ) for the Q5..
    Thanks for your input.
  4. Re: Wheel bolts.
    108 Post(s)
    1816 Post(s)
    m14x1.5x45, funny two part things 8R0 601 295 and £7.33 each
  5. Re: Wheel bolts.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Aren't they the standard bolts for alloys? I assumed that was what OP meant by "original wheel bolts", so already has a set. OP - are the full-size wheels standard (again what part?) or aftermarket?
  6. Re: Wheel bolts.
    108 Post(s)
    1816 Post(s)
    That is the only wheel bolt listed for all Q5's 2009 to 2019 with any factory wheel including the space saver steel rim with folding tyre.
  7. Re: Wheel bolts.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Agreed. I was hoping that if OP can give part number of wheel we can figure it it is not suitable at all, or maybe from a nearly compatible vehicle that he might want to chance usage for really short trips to rest / repair damage. Personally I'd go for using the collaping one, and have a full size spare at home for someone to bring if failure happens close enough by. I'd also take the full size on certain trips like overseas touring. Very handy if on long haul back to ferry, etc.
  8. Re: Wheel bolts.
    Mar 2007
    Sunderland
    Hi guys. Haven’t checked spare wheel for part number yet as at work but was thinking is it possible that when I tried it on it might not have fitted over hub nut assembly properly being too small. I tried it on the front only because I was more concerned about it clearing the caliper. Car is 2012 s line plus on 20 inch wheels.
  9. Re: Wheel bolts.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Ensuring that the wheel centre fits snuggly to the hub boss, sits flat, has right offset, etc are all points to check.
  10. Re: Wheel bolts.
    Mar 2007
    Sunderland
  1. SQ5 Looking Wheel bolts
    By a5sline in forum Wheels and Tyres
    Last Post: 23-02-2015, 12:17 PM
  2. wheel bolts
    By sbt in forum Golf MK6 - 2009 - 2013
    Last Post: 09-07-2011, 10:47 AM
  3. wheel bolts
    By sbt in forum Golf MK5 - 2004 - 2009
    Last Post: 03-07-2011, 03:09 PM
  4. Wheel Bolts
    By Bobster-cyw in forum Golf MK5 - 2004 - 2009
    Last Post: 21-02-2009, 09:14 PM
  5. Do I need new wheel bolts ?
    By martinrhodes in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-04-2007, 08:26 PM
