Thread: Another DAB+ retrofit...
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Another DAB+ retrofit...
    Sep 2008
    Belfast
    6 Post(s)
    I have now completed my upgrade after buying the module and receiving a lot of advice from @neilos100.
    I have a 2010 Avant Le Mans with the 3G basic system but this mod was so easy to gain DAB. I purchased the 4G module (4G0 035 061N) with DAB+ and simply bought the internal aerial (AFAR Amplified) and fakra connection (DOW-10) from dabonwheels rather than going to the extent of using Audi's amplifier and aerial in the OS glass. Simply plug and play! No software issues etc. The aerial is mounted at the top of the tailgate window and tracked down the LHS pillar with the brake light wiring. The signal is fantastic! CP removal is the last thing which is being done this Friday.
    Hopefully this should be of help to someone else looking to do this mod.
    Regards... Graeme
    2010 Audi A6 3.0 TDI Quattro Le Mans Avant (CDYA) Daytona Grey
  2. Re: Another DAB+ retrofit...
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    That’s interesting as my 2009 Dab seems to be dropping stations every time I look another has gone off the list. Wonder if I can directly replace mine.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Another DAB+ retrofit...
    Dec 2007
    43 Post(s)
    Looks like they are the same, do they have component protection?
  4. Re: Another DAB+ retrofit...
    Sep 2008
    Belfast
    6 Post(s)
    Quote Originally Posted by dean warren View Post
    The module Dean?
    Sent from my VOG-L09 using Tapatalk
    Regards... Graeme
  5. Re: Another DAB+ retrofit...
    Dec 2007
    43 Post(s)
    Yes I might upgrade mine in my C6 2009 to the dab+ some people are saying no cp on the unit and some claim removed on ebay...
  6. Re: Another DAB+ retrofit...
    Jul 2013
    76 Post(s)
    From my understanding the unit will generate a CP fault even with a CP removed unit as the CAN Gateway will see the change in serial numbers of the radio.
    The 4G0 035 061 radio unit was for the later models built after 08/11/2010.
    Before this the 4F0 035 061 B or D model would be more suitable.
    Dan
    2009/2010 2.0 TDIe SE
  7. Re: Another DAB+ retrofit...
    Jul 2011
    Near Uxbridge
    From my research these 4G and 4F units are the same with the exception the 4G has DAB + and the 4F only has regular DAB....this means you cannot listen to digital radio on the continent if you have the 4F unit....also there are more and more stations being broadcast on DAB+ in the UK.
    DAB cannot receive a DAB+ signal but a DAB+ tuner is backward compatible with DAB
  8. Re: Another DAB+ retrofit...
    Dec 2007
    43 Post(s)
    Quote Originally Posted by dan2485 View Post
    These aren’t dab+ though are they?
  9. Re: Another DAB+ retrofit...
    Jul 2013
    76 Post(s)
    No there not, my answer was based on not knowing if the 4G0 units were compatilble with the earlier cars.
    Neilos100 has cleared this up.
    Dan
  10. Re: Another DAB+ retrofit...
    Dec 2013
    Liverpool
    10 Post(s)
    Interested in this, do you mind me asking what the cost was?
    2007 2.7 SE quattro saloon
  1. RNS-E DAB retrofit
    By wimpus in forum In Car Entertainment
    Last Post: 19-02-2015, 10:11 PM
  2. ami retrofit
    By Edmunds123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-08-2013, 08:03 PM
  3. Question 3G MMI Retrofit
    By Ilan in forum In Car Entertainment
    Last Post: 28-01-2011, 05:45 AM
  4. pdc retrofit?
    By rajw5 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-01-2009, 01:54 PM
