Thread: CBAB oil pump hex drive
  1. CBAB oil pump hex drive
    Sep 2018
    United Kingdom
    Hi, New to the forum. I own a MK6 Golf 2.0 TDI with a CBAB engine. Car is a 09 plate. Browsing various forums I came across this oil pump failure due to the 77 mm hex drive. Was also noted that this affected early Common Rail engines.
    Now I'm worried that my car may also be affected and could fail. However I came across a thread on this forum from 2013, where one of the comments stated that this problem does not affect the MK6 Golf as the oil pump is driven by chain. I just want to confirm if I've got this right? And the hex drive problem does not affect me.
  2. Re: CBAB oil pump hex drive
    May 2012
    Everywhere
    308 Post(s)
    Ask VW , if they don't know drop the sump as it could be either 77mm or 100mm oil pump drive .
  1. 2.0 Tdi common rail (CBAB)
    By richiek in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-02-2018, 10:31 PM
  2. Cbab no start
    By Audiforlife in forum VCDS - Help Requests
    Last Post: 25-01-2017, 12:32 AM
  3. Clutch, DMF and a CBAB engine
    By furiousgeorge in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-03-2016, 04:03 PM
  4. Balance shaft / oil pump drive issues ?
    By john493 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2014, 09:29 PM
  5. Oil pump drive
    By billcoleman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-08-2010, 12:02 AM
