Thread: Does the A6 C5 use the same wheel bolt pattern as the C6?
  1. Does the A6 C5 use the same wheel bolt pattern as the C6?
    May 2017
    Canterbury, Kent
    57 Post(s)
    Hello to all
    Does the C5 use the same bolt pattern, and therefore be able to use the same wheels, as the C6?
    Many thanks
  2. Re: Does the A6 C5 use the same wheel bolt pattern as the C6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by rjsdavis View Post
    Hello to all
    Many thanks
    It'll depend on a bit more than that, as the wheel offset for a given diameter and J size also matters to give clearance in the arches as steering turns, and that in turn can vary for suspension height on the otherwise same chassis.
    I can't look at the moment, but if aftermarket wheels list same Pitch Circle Diameter (PCD) and number of studs they will at least mount on the hub. For example, Golf, A3, etc are all 5 x 112PCD.
  3. Re: Does the A6 C5 use the same wheel bolt pattern as the C6?
    May 2017
    Canterbury, Kent
    57 Post(s)
    Thanks for the reply.
    Fully appreciate the point you make about offset/wheel size/clearance etc.
    However, this wouldn't affect the bolt pattern afaik. Therefore, is the 5 bolt pattern the same?
    Many thanks
  4. Re: Does the A6 C5 use the same wheel bolt pattern as the C6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Looks like bolt pattern and offset are the same on both eras for at least a "non-extreme" size. 7.5JX17H2 ET43 5/112.
  5. Re: Does the A6 C5 use the same wheel bolt pattern as the C6?
    May 2017
    Canterbury, Kent
    57 Post(s)
    Thanks.
  1. Question Where to buy a new wheel bolt?
    By smoggyrich in forum Golf MK5 - 2004 - 2009
    Last Post: 14-09-2011, 04:33 PM
  2. Request for dimensions or CAD drawing for the audi TT gearbox bolt pattern
    By neilnewboy in forum TT - 8N Forum - 1998 - 2006
    Last Post: 02-09-2008, 12:37 AM
  3. Please Help My Bolt Pattern & offset
    By randyrich86 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-07-2008, 09:52 PM
  4. Stuck Wheel Bolt
    By pete99 in forum Audi A4 - Archive Topics
    Last Post: 29-03-2007, 09:42 PM
  5. bolt pattern
    By stuvette in forum Chat - Completely Off Topic
    Last Post: 05-06-2006, 09:30 AM
