Thread: headlight level sensor
  1. headlight level sensor
    Mar 2007
    9 Post(s)
    Hi all i need to replace the rear axle headlight level sensor on my 2013 audi a4 avant . could anyone tell me if it is just a case of fitting a new sensor or will i need VCDS to program the new part any advice would be appreciated
  2. Re: headlight level sensor
    Ardfern
    8 Post(s)
    I replaced one of these on my 2008 S line saloon several years ago. That, of course was a B8 whereas yours will be a B8.5.
    I needed to do no Vcds adjustment but just wrestled with the mounting bolt, replaced with a fresh sensor and it worked and the fault code did not reappear. Probably yours should be as simple. Good luck.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  3. Re: headlight level sensor
    Apr 2019
    Hi. I have the message stating that my auto headlight adjuster has a fault. Can anyone suggest where to start when diagnosing it? Is this a known/regular fault? I have a 2008 3.0TDi S-line Quattro cabriolet. Thank you.
  1. HELP Highline wiring headlight level sensor
    By markspark71 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-10-2017, 01:48 PM
  2. Question Headlight Level Sensor - 2008 A4
    By elgaz in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-11-2016, 12:12 AM
  3. Question Xenon headlight Front Level Sensor Location?
    By Boy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-03-2015, 11:54 PM
  4. Allroad headlight level sensor
    By big1pie2003 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-07-2014, 10:36 PM
  5. Question H7 Headlight Level Adjustment
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-09-2010, 05:53 PM
