Thread: A6 4F Avant Driver's side electric window issue
  1. A6 4F Avant Driver's side electric window issue
    Mar 2020
    Sheffield
    Hi all,
    First time poster here, long time lurker.
    I have owned a 2007 Audi A6 Avant Le Mans 3.0tdi 4F since Feb this year. Very pleased with it so far!
    It has recently developed an issue with the driver's side electric window:
    Upon pressing down it will go down slowly all the way. (Slowly compared to the passenger side).
    When pressing to bring it back up it will come up even slower and then get stuck about 1/2 way up, freeze and then go back down slowly.
    I am only able to close it up by holding up the button and forcing the window glass up with my other hand.
    I tried spraying a bit of silicone lubricant into the channels but that didn't seem to make any difference (other than giving a greasy window!)
    The switch is clearly OK, so I suspect the issue is either with the motor or with something causing interference, perhaps a broken clip or other internal?
    I'm fully prepared to strip the door. I read it's a bit of a job so it would be good to know potentially what I'm looking for and any spares I could have at the ready.
    Before making this post I searched to see if this issue was already covered to no avail. Any advice or a link to an existing post if there is one would be appreciated.
  2. Re: A6 4F Avant Driver's side electric window issue
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    My rear we’re similar, I couldn’t close them, they would sense a restriction and drop back an inch or so., but spray on the rubbers worked for me, my rear windows work fine now. I dropped the windows right down, sprayed the lube into the groves and sent the window back up. No greasy windows.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: A6 4F Avant Driver's side electric window issue
    Jul 2008
    Lisburn
    16 Post(s)
    any weird noises? the regulator could be on its way out
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  4. Re: A6 4F Avant Driver's side electric window issue
    Mar 2020
    Sheffield
    No weird noises. It's just very slow and seems like there's some sort of resistance somewhere.
  5. Re: A6 4F Avant Driver's side electric window issue
    Jul 2008
    Lisburn
    16 Post(s)
    could be a bad connection causing resistance so the motor is not getting 12V and the current increases to compensate - then it trips out as if a blockage when the current gets too high. An old B5 passat i had a splice in the loom had failed for the windows - it was below the carpets and the B5s were known for their water ingress issues...
    Stewart
  1. Driver side electric window not working
    By vipergrm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2015, 09:14 PM
  2. Please Help A4 b7 electric window switches (driver's side door pod)
    By quattro_v6 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-10-2013, 06:41 PM
  3. Please Help Driver side electric window fault
    By stevehammond76 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-05-2009, 07:45 PM
  4. Please Help Driver side electric window
    By faizulali in forum Audi A3 - Archive Topics
    Last Post: 20-01-2009, 04:48 PM
  5. driver side electric window
    By sumanb82 in forum Audi A3 - Archive Topics
    Last Post: 12-04-2007, 10:23 PM
