Thread: Removed inlet manifold - should I spray carb cleaner down inlet valves?
  1. Removed inlet manifold - should I spray carb cleaner down inlet valves?
    West Sussex
    I'm replacing the egr valve on my wife's 06 BKD 2.0 tdi. I've removed and cleaned the manifold and the asv. Wondering whether I should spray any carb cleaner down the ports for the inlet valves while I have the manifold off, or just leave alone? I've seen this done on YouTube but I'm not convinced. Cheers.
  2. Re: Removed inlet manifold - should I spray carb cleaner down inlet valves?
    1840 Post(s)
    No way! If you spray anything volatile in there it can pool and when you start it, the engine will run away and can then pull oil from the sump and.... we’ll the rest is history, smokey history. To get the system clean we use System cleaner diesel which is water based.
  3. Re: Removed inlet manifold - should I spray carb cleaner down inlet valves?
    West Sussex
    Cheers Crasher. Is it worth spraying through the ports with the cleaner you suggest or just leave alone?
  4. Re: Removed inlet manifold - should I spray carb cleaner down inlet valves?
    1840 Post(s)
    That spray is used running through the intake, some people just use water. A few months ago we had a chap on the phone who had seen someone on YouTube spray water down the inlet so he squirted water into his from a bottle and the engine locked up... he wondered if he may have hurt it!
  5. Re: Removed inlet manifold - should I spray carb cleaner down inlet valves?
    West Sussex
    Oh my....Anyway car all back together, no more egr faults and drives lovely
    Have to say, this is one filthy job. Managed to make 1 disposable glove and my wife's marigolds last for the whole thing. She doesn't want them back...
  6. Re: Removed inlet manifold - should I spray carb cleaner down inlet valves?
    1840 Post(s)
    It’s goo that can make its mark throughout your working area and beyond. Just try working with Aluminium paste...
  1. Replies: 1
    Last Post: 15-07-2017, 10:53 AM
  2. Please Help Cannot release inlet manifold despite all bolts removed
    By yesican in forum Golf MK5 - 2004 - 2009
    Last Post: 25-06-2012, 11:43 PM
  3. Oil in the Inlet Manifold and EGR
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-08-2011, 04:01 PM
  4. Inlet manifold??
    By russvr6 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-08-2008, 06:33 PM
  5. 1.9tdi mk3 inlet valves heavy carbon deposits
    By Royzboy in forum Golf MK3 - 1993 - 1999
    Last Post: 28-10-2007, 08:46 PM
