Thread: Fuses
  1. Fuses
    Nov 2013
    west midlands
    Hi all just brought a mark 5 57 plate golf 140 bhp
    I can’t go into details as you’d never believe me but the cars been messed with ie things taken out and fuses missing
    I’ve looked at fuse diagrams online but seem to be hitting a wall as some say there’s a fuse and the holders empty
    I need fuse for the radio in the car and in the fuse box it’s possible it’s missing as the radio doesn’t work
    The 12v socket in the car doesn’t work also.
    Any help be appreciated I know it’s a weird one chasing what’s not there
  2. Re: Fuses
    Nov 2013
    west midlands
    I found 2 pics of the same fuse box on this model the radio fuse was in a different place in each
    I found the fuse (or lack of) and the radios working now
    Just need the fuse for
    Air con
    Passenger headlight
    12v socket in front of the car
    For a 57 plate gt facelift mark 5
  3. Re: Fuses
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    For 2007 model try 20A fuse in slot 42 of dash box for the cigarette / power sockets. Or 24 if it happens to be the earlier wiring.
    And 15A fuses 8 and 19 in engine for radio maybe.
  4. Re: Fuses
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Don't both left and right headlamp come direct from same control unit, so same fuse? Can you see 12V at passenger one with a multimeter? Is run to earth good?
  5. Re: Fuses
    Nov 2013
    west midlands
    Thanks all I haven’t checked any wiring as been so busy at work just wanted to know fuses for when I get an hour
    The reason I asked I don’t seem to have a side light either
    Seeing though the radio fuse was completely missing this car could be a be tedious lol
  6. Re: Fuses
    Nov 2013
    west midlands
    Thanks all 42 was correct for the cigarette light so does that mean I have the newer wiring?
    Headlight was the bulb so swapped 2 new ones as they were some cheap blue things
    Who designed the sidelight configuration was a nightmare
    I think the actual lenses part in be
    main beam side projector part is loose does anyone know how to get it to clip back in correctly
    If so I’ll try get a decent copy for the future
    Like before fuse was missing all working now
    Ac doesn’t have any juice in it as checked the pressure so didn’t bother chasing that
  7. Re: Fuses
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    "Post May 2007" wiring, which is what you'd expect for the reg, but not always the case.
  1. Question Fuses
    By jjsf20 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-01-2017, 12:33 PM
  2. Fuses
    By RichardSEL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-02-2016, 11:37 AM
  3. Please Help fuses ?
    By plumo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2013, 06:52 PM
  4. Fuse, more Fuses and D*mn Fuses
    By deryckt in forum Touran - Sharan - Caravelle
    Last Post: 21-05-2010, 07:19 PM
  5. Help with fuses.
    By Crockett in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2008, 07:28 PM
