Thread: Wiring installation of Dash Cam
  1. Wiring installation of Dash Cam
    Mar 2009
    Cheshire
    I want to wire my Netbase Dash cam to one of the side fuse areas, either drivers or passenger side using a piggy back fuse.
    My power cable to the Netbase has two wires, one red, one black.
    I am right to assume that the red wire is connected to the piggy back fuse connector and the black is ground to metal on the car?
    Also which fuse is best to use on which side of the car.
    The car is a 2009 A8.
    Thanks for any advice.
    Sent from my SM-G980F using Tapatalk
  2. Re: Wiring installation of Dash Cam
    Jun 2006
    UK, Registered Homeless
    There is already a connector in the ovehead light for a camera (lane change assist). It is 12V with the ignition on.
    You can put a 12v - USB convertor in that area, there is space. I can't remember which pins are live - you will have to test, but I think it's the middle 2 (2 & 3). You just have to poke the cable in the gap between the headlining and window and pull it through.
    Audi A8L- 2006 - 3.0TDI
  3. Re: Wiring installation of Dash Cam
    Mar 2009
    Cheshire
    Quote Originally Posted by snapdragon View Post
    Thanks snapdragon. If I may indulge a little more? If I was to still use the left hand fuse panel and choose the lane assist fuse which is currently empty how would I need to wire up to the piggy back fuse. Li have already lopped off the cigarette lighter style connector on the end of my dashcam power cable exposing a black and red wire. Is it red to the fuse and black to ground or are they both to the fuse? Thanks again
  4. Re: Wiring installation of Dash Cam
    Mar 2016
    Minervois, France
    40 Post(s)
    If your dashcam is a Nextbase rather than a Netbase, you may find that the cigarette lighter adapter you "lopped off" is actually a converter from 12 volts to 5 volts.
    If you connect the dashcam directly to a 12 volt supply you may smoke it
    Don't force it - get a bigger hammer!
    1996 A4 B5 Avant 1.8T engine code AEB automatic with 66,000 kms - 41,000 miles on 16/09/19.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  5. Re: Wiring installation of Dash Cam
    Mar 2009
    Cheshire
    Quote Originally Posted by FrenchAudi View Post
    If your dashcam is a Nextbase rather than a Netbase, you may find that the cigarette lighter adapter you "lopped off" may contain a converter from 12 volts to 5 volts.
    Right I see. Many thanks for that.
  6. Re: Wiring installation of Dash Cam
    Jun 2006
    Car DC Converter Connector 12V To 5V 3A 15W Duble USB Output Power Adapter 701160642719 | eBay
    You can use something like this to convert 12v back to 5V USB.
    The red wire goes to the piggy back fuse and the black to negative (ground) - usually you will find a nut on the structure of the car with one or more brown wires attached to it. Use this location.
  7. Re: Wiring installation of Dash Cam
    Mar 2009
    Cheshire
    Thanks Snapdragon I appreciate the help and advice. Can I apply the same principal to my phone charger? Its one of those that opens and closes automatically and charges the phone via wireless. It also currently has a cigarette lighter adaptor on the end.
    I was thinking of wiring this to the drivers side fuse area piggy backing off one of the cigarette lighter fuses. I assume i would need to also put thus through a converter?As front and back cigarette lighter fuses are in this area. I.e one for the dash cam and one for the phone holder? I was thinking of using them. What do you think?
  8. Re: Wiring installation of Dash Cam
    Mar 2009
    Cheshire
  9. Re: Wiring installation of Dash Cam
    Mar 2009
    Cheshire
    All sorted. Both my dash cam and phone charger now installed via direct connection to fuse box on drivers side.
  1. Dual Dash Cam Installation
    By Brownstone1892 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-07-2020, 10:50 PM
  2. Question Dash cam installation
    By UMEL in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 11-01-2017, 03:11 PM
  3. Question Alhambra dash cam installation
    By jcrgordon in forum Alhambra
    Last Post: 13-02-2015, 11:53 PM
  4. Dash camera installation
    By Goatistuta in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-01-2015, 09:18 PM
  5. Question Golf MK3 AMP Wiring Kit Installation.
    By gtijason2.0 in forum Golf MK3 - 1993 - 1999
    Last Post: 14-09-2009, 12:59 PM
