Thread: Another coolant leak! Photos within. 3.0Tdi Q7
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Another coolant leak! Photos within. 3.0Tdi Q7
    Oct 2010
    Chesterfield
    Hello. IÂ’ve just had a little bit of a trawl through the many threads about coolant loss.
    Our 2016 3.0 has been using around 1l per 500 miles for the last couple of months. Undertray removal shows a clear path of the coolant but nothing visible without significant disassembly.
    From the photographs does anyone recognise the pathway and want to prepare me for what’s coming! 🤣
    Thanks guys, David.
  2. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Oct 2010
    Chesterfield
    Photos will follow shortly.
  3. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Jul 2010
    uk
    183 Post(s)
    As you e probably seem in the thread a common issue on the car - not sure what the cost is to fix out of warranty but you could probably argue it’s a know issue.
    Not sure if there was a TSB at all for it?
  4. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Nov 2015
    U.K.
    78 Post(s)
    I had a look on my paperwork it just says “new coolant solenoid value” and as I had the extended warranty that covered it, minus excess. But my dealer told me because most of it is a load of labour to dismantle/assemble the engine to get to it, it would have cost retail just short of £2k. Eek.
    | Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating |
  5. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Oct 2010
    Chesterfield
    Crikey. I can see it’s going to be no mean feat to find. The car actually went in for a dealer service on Friday and the leak was picked up. £850 quoted to assess.
    The car had been without fault pre service - yet didn’t make it home before throwing warnings and and has just been recovered about an hour ago. Looks like it’s no longer charging. You couldn’t make it up!
    Thanks for the replies - I’ll figure out the photo’s tomorrow.
  6. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Nov 2015
    U.K.
    78 Post(s)
    Quote Originally Posted by davidjessop View Post
    Use a different dealer or specialist independent? They shouldn’t be quoting £850 to diagnose a fault you will pay to fix surely? Will that be offset against the repair? Ouch. FYI my dealer made a mistake when reassembling the engine, they just forgot to attach one of the leads for the cylinder heat plugs properly. Engine fault yellow light etc. They diagnosed and fixed it same day and I got some compo for the hassle as they were hugely apologetic.
  7. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Oct 2010
    Chesterfield
    I think the issue is that to accurately diagnose the disassembly process is pretty time heavy. Front off, and a fairly major strip down to below the intake manifolds. No going back at that point is there?!
  8. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Nov 2015
    U.K.
    78 Post(s)
    My dealer didn’t need to do that to diagnose the problem... very likely to be the known issue.
  9. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Mar 2010
    37 Post(s)
    228 Post(s)
    David
    This is a well known issue. Parts are circa £150/200 to buy, its the 3 hours taking fuel lines/pipes off the top of the engine to replace the Coolant Solenoid. That is the culprit. Nothing more than "poor design" and it wears out over time. Needs to be replaced with a new version and put everything back in reverse
    Took me 5 hours....
    This is the culprit part.. the valve that "slowly" leaks.
    and this is the effort to get to it.. its right down the middle. but its all do-able from the top down.
    The hardest bit of all is putting the intake manifold valves back on.. One screw is just a nightmare to get your hands too...
    The valve itself is about £80, but you need to replace seals etc and screws so it bumps up to the £150+ mark in parts. but the dealer is right, the cost is all labour...
    The TSB (Technical Service Bulletin) is 2047044/8
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  10. Re: Another coolant leak! Photos within. 3.0Tdi Q7
    Mar 2010
    37 Post(s)
    228 Post(s)
    Nah, not true. You can see the leak by just taking the engine cover off and a really bright torch shining into a very specific place.. you can see the coolant dripping out...
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
    By SchrodingersCat in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-04-2020, 09:43 AM
  3. Guidance on oil leak in Audi A4 B8 2.0l CAGA TDI engine (with photos)
    Last Post: 13-11-2019, 09:44 PM
  4. Question Golf mk5 2.0tdi loosing coolant but there is no leak??
    By MCTOPJONES in forum Golf MK5 - 2004 - 2009
    Last Post: 18-11-2017, 11:16 PM
  5. Please Help Oil leak mk5 2004 TDi (Photos) Whats this pipe? :D
    By mk5mat in forum Golf MK5 - 2004 - 2009
    Last Post: 21-05-2011, 09:33 PM
