Thread: 2006 2.0 tdi
  1. 2006 2.0 tdi
    Jun 2020
    Birmingham
    Hi to all
    Have just purchased a 2006 2.0 tdi in excellent condition, however, the engine sounds really lumpy with no power when driving. It will drive along at any speed once you get there, but when trying to accelerate, the engine rattles as if its "pinking" and doesn't pick up. Have had egr checked and cleaned. Loom was checked and appeared fine. Injectors all have power going to them but have not been removed to be checked. Could the intercooler be the problem?? Car has done 200000 miles
    Any help would be appreciated as its a nice clean car with no other issues.
  2. Re: 2006 2.0 tdi
    Oct 2018
    York
    9 Post(s)
    It's a 2.0tdi....what, though? What's the engine code? From what you say, I'd be inclined to think a leak on the induction side, given no DTCs. Can you hear a whistling/siren type sound when you accelerate? Is there any smoke?
  3. Re: 2006 2.0 tdi
    1836 Post(s)
    I would guess it is a Golf 5 with a BKD engine. The first thing I would do (after a code read) is open up the fuel filter and check for engine oil contamination.
  4. Re: 2006 2.0 tdi
    Oct 2018
    York
    9 Post(s)
    Yes, this. I had a Passat with the BKP motor, fuel contaminated with engine oil due to tandem pump gasket failure. Intermittent no-start condition, sometimes ran but with DTCs suggesting injector malfunction. Once gasket renewed and fuel system purged, ran like a dream.
  5. Re: 2006 2.0 tdi
    Mar 2010
    Derry ireland
    60 Post(s)
    I would certainly remove injectors & get the spray pattern checked for starters. Owing to the mileage this vehicle has done
  1. Replies: 4
    Last Post: 06-06-2015, 12:57 PM
  2. Replies: 6
    Last Post: 20-02-2012, 08:34 PM
  3. RNS-e into 2006 B7
    By TKDnick in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-11-2010, 03:50 PM
  4. Vw 2006 FOX
    By s8tan in forum Polo - Derby - Lupo - Fox
    Last Post: 27-01-2008, 08:50 AM
  5. 2006 Fox
    By IntegraH in forum Polo - Derby - Lupo - Fox
    Last Post: 30-11-2007, 02:00 AM
