Thread: A4 B8 Battery Change
Results 1 to 1 of 1
  1. A4 B8 Battery Change
    Aug 2015
    Cambridgeshire
    After reading a number of threads with conflicting info, I wanted to share my experience.
    My B8 was fitted with the original Moll 8k0 915 105 E 12V 450A 95Ah DIN (760A EN/SAE) battery, but it was no longer holding charge so I opted to replace it with a G3 Varta Blue Dynamic 12V 95Ah 800A at a cost of £98.94 (inc VAT and del.)
    I didn't bother with connecting a backup power source, so there was about 10 minutes or so with no power in the system which didn't cause any issues later. Once the new battery was connected, I checked the power meter in the MMI but it was greyed out; curiosity go the better of me so I started the car and still greyed out.
    Fortunately I had borrowed my mates VCDS setup and coded as follows:
    [19 - CAN-Gateway]
    [Long Adaptation-0A]
    [Channel] 004
    [Read]
    For my car, I did the following: Part number remained the same* | Changed the manufacturer code to VA0 | Entered the date and last 4 digits of the number etched into the battery
    8K0915105E VA0 YYMMDDSSSS
    [Test]
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Started the car and the MMI battery state was at 100%
    I checked measuring blocks 018, 019 & 020 showed the battery SOC was 86% and the MMI was displaying 100% (original battery was something like SOC 25%, MMI 40%)
    Lots of people have success with just changing the last digit of the serial number. I also tried this method and the battery registered as 100% in the MMI but I thought it was a bit cleaner to add the date and battery specific data, albeit 4 digits following a similar format of the original BEM.
    *It's probably worth mentioning there were 2 spaces between the part number and manufacturer code which I inadvertently removed and the code failed to accept until they were entered again.
    0 3 0
  1. Battery Change
    By andyha2000 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-08-2018, 08:23 PM
  2. Question Battery change
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-01-2011, 06:48 PM
  3. Battery change, How ?
    By hod in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2010, 05:23 PM
  4. Question How do I change my battery
    By sam-g- in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2009, 09:20 PM
  5. V6 battery change.
    By vma99r in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-11-2008, 07:16 PM
