Thread: intermittent sound- fault code 16349
  1. intermittent sound- fault code 16349
    May 2019
    Hi all.
    i have a problem with my Audi A8,2014. Couple of times a week,i will play music via sd card and it then goes quiet,comes back on,every few seconds. its just sound and no sound. i think its the same with radio but cant be 100% as i don`t listen to radio much. When i stop and get out and come back 10 minutes later,its fine. It seems to reset itself. i have done a MMI reset as well but doesn`t seem to correct it.
    I did a scan and it came back 16349-CONTROL MODULE-ERROR IN OUTPUT STAGE 014 DEFECTIVE.
    I have done a google search but cant find the same problem as i am having.
    Any help would be appreciated.
    thanks.
    Andy
  2. Re: intermittent sound- fault code 16349
    1836 Post(s)
    That means the amplifier is faulty, is the system Audi Active, Bose or B&O?
  3. Re: intermittent sound- fault code 16349
    May 2019
    hiya.
    it is a Bose system.
    is it something i can replace myself and how much are they.
    where is it located.
    thanks
  4. Re: intermittent sound- fault code 16349
    1836 Post(s)
    If it is the one I think it is in the boot and part number 4G0 035 223 C which costs £1215 retail from Audi. New and unmodified it must be coded into the car to deal with the component protection and also coded to the system using the soft coding value from the old unit.
  1. Fault 00467 intermittent surging and whooshing sound
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2017, 07:28 PM
  2. A3 won't start fault code 01176 - key - 008 - implausible signal - intermittent
    By dontclickonthis in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-09-2016, 03:10 PM
  3. Audi A6 2.7TDI w. fault code: EGR System - Insufficient Flow - Intermittent
    By MartinCB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-04-2016, 01:26 PM
  4. Replies: 1
    Last Post: 06-03-2015, 01:59 PM
  5. Replies: 8
    Last Post: 06-11-2014, 09:56 AM
