Thread: Braking issue
  1. Braking issue
    May 2020
    Uk
    I am new on this forum so I apologise for any errors.
    I have a vw new beetle. X reg year 2000.
    The issue I am having is that I have an issue with the brakes. The brake pads have been replaced and discs are all good and the system has been bleed twice.
    When I am driving and I fully press the brake pedal the car dosnt stop instantly.its almost like the pads are not pushing down hard enough on the brake discs.
    There are no noises coming from the braking system and no warning lights either, plus no error codes from the odb read out.
    The brake pedal does not feel spongy or soft and once pressed down the pedal dosnt sink.
    Any help or advice is much appreciated.
    Thank you in advance.
  2. Re: Braking issue
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    New pads do need use to bed in, but you could also have a problem with the brake servo.
    There is a rubber vacuum pipe attached to the brake servo, check you have a good vacuum from it when pulled off the servo with the engine running.
  3. Re: Braking issue
    1837 Post(s)
    Do you know if any air was allowed into the ABS pump or master cylinder either during work or letting the reservoir run dry whilst bleeding? Was the bleeding done just the old pedal press method, pressure assisted or pressure assisted and using a diagnostic computer to to purge the system?
  1. Braking in wet issue
    By SpeedJunky in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-10-2016, 12:05 PM
  2. Odd brake issue after hard braking
    By dysonco in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-12-2011, 12:38 PM
  3. Braking issue 1996 a4 tdi
    By jamiesd in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2011, 11:13 AM
  4. braking issue - please help
    By avantiblue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-03-2010, 03:13 PM
  5. MK3 1.8L SE - Braking Issue
    By BugBit in forum Golf MK3 - 1993 - 1999
    Last Post: 10-12-2007, 01:53 PM
