Thread: Still the lack of power.
  1. Still the lack of power.
    Starts to accelerate, sudden loss off power, NO response from pedal (not even limp home mode), check engine warning light on, higher than normal revs when out of gear.
    Had these problems a couple of years now, early on the problem was intermittent, every few days to few months. Tried several solutions, cleaned the ECU box out of damp, replaced the accelerator peddle, and even changed the turbo; after the turbo it was OK for months and it started up again. Found I could set off in higher gears and the fault would rectify, but it's given up the ghost completely now.
    Results of the vagcom below, any suggestions?
    I have not changed the MAF, and I have seen it could be the gear box or a wiring loom; and the ECU is blanked off.
    Thanks.
    Code:
    Chassis Type: 8D - Audi A4 B5 (1995 > 2001)
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine        Labels: 038-906-019-AJM.lbl
       Part No: 038 906 019 BR
       Component: 1,9l R4 EDC G000SG  1064
       Coding: 00002
       Shop #: WSC 06325
       VCID: 68DF5E2B0886005E3C3-4A9C
    5 Faults Found:
    18039 - Accelerator Position Sensor (G79)
                P1631 - 35-10 - Signal too High - Intermittent
    18040 - Accelerator Position Sensor (G79)
                P1632 - 35-10 - Power Supply Malfunction - Intermittent
    17554 - Mass Air Flow Sensor (G70)
                P1146 - 35-10 - Supply Voltage - Intermittent
    17553 - Mass Air Flow Sensor (G70)
                P1145 - 35-10 - Short to Plus - Intermittent
    17965 - Charge Pressure Control
                P1557 - 35-10 - Positive Deviation - Intermittent
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
       Part No: 8E0 614 111 AH
       Component: ABS/ASR 5.3 FRONT   D10
       Coding: 00012
       Shop #: WSC 06435
       VCID: 64C74A1BF4AE643E10B-5072
    No fault code found.
    Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
       Part No: 8D0 820 043 Q
       Component: A4     KLIMAAUTOMAT D57
       Coding: 00044
       Shop #: WSC 06325
       VCID: 2E53E833EAE29E6E36F-254E
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
                41-00 - Blocked or No Voltage
    Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
       Part No: 8D0 959 655 J
       Component: Airbag Front+Seite 1001
       Coding: 01106
       Shop #: WSC 06325
       VCID: 3D71DF7F378475F6BF5-5072
    Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
       Part No: 8D0 920 980
       Component: B5-KOMBIINSTR. VDO D11
       Coding: 00440
       Shop #: WSC 00000
       VCID: E8DFDE2B8886805EBC3-5000
       Component: AUZ7Z0Y1411444
       ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ     AUZ7Z0Y1411444
    Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
       Part No: 8D0 862 257 E
       Component: CV-Pump, Alarm, RC  D13
       Coding: 13130
       Shop #: WSC 06325
       VCID: 2F6DF537EDE897663D9-4DD6
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00102
       Shop #: WSC 06325
       VCID: E0CFC60B60B6F81E743-4A9C
    2 Faults Found:
    01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
                27-10 - Implausible Signal - Intermittent
    01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
                27-00 - Implausible Signal
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 8D0 035 195
       Component:  Radio              D00
       Coding: 00205
       Shop #: WSC 06325
       VCID: E3C5C90771A0E306691-4A3A
    End   ---------------------------------------------------------------------
    audi a4 allroad quattro 2.0 tdi Avant 2010
  2. Re: Still the lack of power.
    135 Post(s)
    2038 Post(s)
    Clear the codes, take it for a run and do a rescan and post.
  3. Re: Still the lack of power.
    I'll do that, ordered a used mag from ebay, i'll do it after that has arrived.
  4. Re: Still the lack of power.
    135 Post(s)
    2038 Post(s)
    Quote Originally Posted by minny View Post
  5. Re: Still the lack of power.
    Heat getting to you there lad?
    I can run it without putting the maf first, then put it on; it is one of the few things, along with examining all the wiring, that I have not done, so for 20 quid, worth a pop.
  6. Re: Still the lack of power.
    135 Post(s)
    2038 Post(s)
    No much! I have more hair than in an 80's German pop video (never wanted a mullet, got one now) and as I have got older, anything over 18 degrees and I start melting...
  1. Supermarket Diesel Passat B6 2.0 TDi BKP Engine Poor Power Lack of power
    By woody80uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2012, 11:29 AM
  2. lack of power
    By charlieboy180 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2009, 12:17 AM
  3. 1.8t lack of power
    By 1.8t bus in forum New Member Introductions
    Last Post: 08-09-2007, 06:00 PM
  4. S3 lack of power
    By Blair in forum Audi A3 - Archive Topics
    Last Post: 21-05-2007, 01:44 PM
  5. TDI lack of power
    By Mk2 Forever in forum Passat - Archive Topics
    Last Post: 03-08-2006, 01:25 PM
