Thread: Thermostat change on 2010 Passatt
  1. Question Thermostat change on 2010 Passatt
    Jul 2007
    Widnes, Cheshire
    Hi, I was wondering if anyone could point me in the right direction to some good instructions (video or pictures) of how to replace my thermostat on my 2010 passat I will also be doing a coolant flush at the same time?
  2. Re: Thermostat change on 2010 Passatt
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    I have the official procedure documented if you want to PM me your email address. I'll dig it out and email it to you.
    Mad Mitch
  3. Re: Thermostat change on 2010 Passatt
    Jul 2007
    Widnes, Cheshire
    Thanks for the reply, I did pm you last night but my battery went as I sent it so not sure if you got it ok.
  4. Re: Thermostat change on 2010 Passatt
    Jan 2012
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by Jak68 View Post
    As the process involves disconnecting fuel lines and components it is important to ensure the HPFP (main full pump) retains fuel as it is needed to lubricate the HPFP which would fail if it became dry. It is always worth priming / bleeding the system before the first start following reinstallation of fuel pump components to be on the safe side. This can be done by running the 'Check fuel pump pressurisation' option in Basic Settings (VCDS).
    Mad Mitch
  1. Change thermostat as part of timing belt change?
    By spartacus 68 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2017, 01:26 PM
  2. Thermostat location - A6 2010 - 4F2
    By necstandards in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-05-2017, 05:12 PM
  3. Fuel filter change passatt tdi2001
    By Imalumberjack75 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2015, 08:42 PM
  4. thermostat change on a 2.0 tdi
    By ejs1995 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-01-2014, 04:28 PM
  5. v5 passatt spark plug change
    By clixmick in forum Chat - Anything with wheels
    Last Post: 27-10-2007, 10:04 AM
