Thread: Fuel additives
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. Fuel additives
    Aug 2018
    Swindon
    22 Post(s)
    Hi... remember I know nowt about these odd diesel engines ..... this is the first one I've ever had in 40 odd years of petrol head enjoyment !! This is a 3.0 turbo V6 Allroad
    Due to the present covid crisis, the beast is getting very few drives, and those that do occur are shortish - max about 15-20 miles, and that is going the long way round to get to the few places I must get to !! otherwise , for health reasons, we simply don't go out.
    Everything I read tells me that short trips are bad for most bits of this engine from the Turbo through to the Cat to the DPF .. but I have no choice at the moment.
    I am considering using a fuel additive in an attempt to reduce any problems, and the best I seem to find is "Archoil AR6400-D Max Professional" which claims to fix all the problems mentioned.
    Question then, for you guys who "know" these things ... is this a "snakeoil" type claim .. or do these additives work ?? Is it likely to cause any damage or other problems to this engine ?? Is there anything else I should know/be aware of before going down this track ??
    Regards and stay safe .... E
    2014 Audi A6 Allroad (C7, 245bhp)
  2. Re: Fuel additives
    May 2012
    Everywhere
    308 Post(s)
    2 Stroke oil - JASO FB spec .
    2-EHN .
  3. Re: Fuel additives
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    I've started adding that to my breakfast cereal now.
  4. Re: Fuel additives
    May 2008
    40 Post(s)
    You are 99.99 percent worrying over nothing, and if something does go wrong (which it wont) it was going to go wrong anyway, lack of use or not.
    Pretty much all the fuel additives are snake oil.
    The only ones that actually do anything are the fuel stabiliser type used in the leisure boat world, and all they basically do is stop the growth of the fuel bug.
    Wifes 3.0tdi has done all of maybe 20 miles in the last 8 weeks, and if it does another 20 miles in the nxt 5 weeks I would be amazed.
  5. Re: Fuel additives
    May 2012
    Everywhere
    308 Post(s)
    It's not snake oil when you have your own set of several years worth of Mot smoke opacity test results .
    I doubted the accuracy from machine to machine , when in my new ownership the average was 0.02 from the past year somewhere else .
    2T alone halved it !
    As for 2-EHN it's a bonified Cetane booster and is added to diesel , premium diesel has more supposedly but it's all a con as Cetane number is not disclosed in UK .
    And cheaper to add yourself , buy 5L , I add 200ml 2T and 40ml 2- EHN pre made up in multiple used 250ml Redex bottles.
  6. Re: Fuel additives
    May 2008
    40 Post(s)
    Still snake oil until you can prove via reliable results, otherwise it is just your opinion, same as mine, which both mean squat.
    Note the makers have very little in the way of quantifiable test results?
    There is a thread somewhere, on this forum I think? with a reply from the makers of 2so saying, do not use their product in diesel engines.
  7. Re: Fuel additives
    May 2008
    40 Post(s)
    Ha found it, looked for ages other times and could not find the thread, first search just now and bang there it is!
    Post number 11, Diesel Fuel system cleaner / injector cleaner - Page 2
  8. Re: Fuel additives
    May 2012
    Everywhere
    308 Post(s)
    Like a lot of white papers they are technically flawed , it's studying JASO FC 2 Stroke , those in the know use JASO FB , big base oil difference !!
    I have great pleasure of late on debunking a white paper on the drive by wire throttle improver 'Sprint Booster' I've not yet mentioned the huge technical flaw yet , it's very simple but has worldwide been overlooked, similar mistake to this JASO FC 2T technical study .
    So why do you think my smoke opacity halved , lol ?
  9. Re: Fuel additives
    May 2008
    40 Post(s)
    Sounds to me like you can solve all the worlds pwoblems all on your own.
  10. Re: Fuel additives
    Jan 2013
    109 Post(s)
    Yup, provided they can all be solved with a good healthy dollop of 2 stroke. ��
    1 1 0
  1. Fuel / additives
    By bops6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-09-2015, 11:08 AM
  2. Fuel and oil additives
    By Specs82 in forum 1.9TDi - Engine
    Last Post: 08-01-2014, 11:45 PM
  3. Fuel Additives
    By TDiBoraSam in forum Golf MK5 - 2004 - 2009
    Last Post: 30-06-2013, 09:34 AM
  4. Fuel Additives
    By GilesC in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2007, 01:07 PM
  5. Fuel Additives
    By 130geegees in forum Passat - Archive Topics
    Last Post: 19-08-2006, 06:39 PM
