Thread: Does 2011 A3 need battery coding?
  1. Does 2011 A3 need battery coding?
    Aug 2007
    Derbyshire
    Hopefully a short one. A freind has a 2011 2l petrol A3. In Febuary his battery (original) was completely flat and he bought a new Bosch S4 (74Ah) which I fitted for him. Yesterday it wouldn't start or turn over. When I went to look today the battery was completly flat, 4V off-load. Being retired he doesn't use the car much - maybe once a week a few miles to the shops and back. Normally I would suspect that he's just not using it enough, but it seemed odd that the battery was so flat (unless he has left things on, but he says not). He then said he had been looking on the internet and some cars need new batteries coding - can anyone tell me if this model does need replacement battery coding? Thanks.
  2. Re: Does 2011 A3 need battery coding?
    Aug 2007
    Derbyshire
    I don't think it is the 2l, rather the 1.8tfsi
  3. Re: Does 2011 A3 need battery coding?
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    It's usually only cars fitted with stop/start systems ( and therefore AGM or EFB batteries ) that need coding.
  4. Re: Does 2011 A3 need battery coding?
    Yes, I fitted an S4 to my wife's old A4 Avant and no coding was needed. When the battery on my A3 with stop/start had to be replaced, that did need coding.
    Hold on: my car is a late 2011 A3 2 litre TDI and has stop/start. Are you sure about the battery? The garage was going to fit a standard S4 on mine until they realised it had stop/start which requires a much more powerful (and expensive) one.
  5. Re: Does 2011 A3 need battery coding?
    Aug 2007
    Derbyshire
    Thanks for the info. It doesn't have stop/start nor the multi-media display which seem to be pointers towards coding required. However, the owners manual that came with it states coding is needed when replacing the battery. I connected it to VCDS and was able to go through the coding proceedure without issue. Hopefully that will improve it a bit, but I'm still not convinced it will make much difference - I think he just needs to use it more (it's only got 35k on the clock). There must be loads of similar cars that have had replacement batteries fitted without being recoded.
  6. Re: Does 2011 A3 need battery coding?
    May 2015
    Southampton
    I have a 2011 2.0 TDI with stop/start and when my battery died 4 years ago I just fitted a replacement from Halfords and has been no problem ever since.
  1. Coding a new battery
    By 54A4Avant in forum VCDS - General Questions
    Last Post: 04-01-2018, 08:14 PM
  2. Question Help coding new battery
    By Darks in forum VCDS - Help Requests
    Last Post: 28-09-2017, 09:38 PM
  3. Battery coding
    By glh-ronin in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2016, 11:06 PM
  4. 2011 vw caddy coding URGENT!!!!!
    By Richard Paw in forum VCDS - Help Requests
    Last Post: 25-04-2014, 09:52 PM
  5. Please Help Battery coding
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2013, 07:42 AM
