Thread: Buying - A5 Cab 150 v 177
  1. Buying - A5 Cab 150 v 177
    Nov 2015
    Sheffield - England
    Evening gents,
    I'm in the market for an A5 cab. Seen a couple I'm going to be viewing. One's a MY15 S Line Special edition plus 177bhp 35000 miles and the other a MY14 S Line Sepecial Edition 50000 miles.
    The write up on both is pretty vague, can anyone ashed any light on the model differences and how they stack against my current MY10 A6 S Line Le Mans
    Also, the obvious 27bhp aside is there much difference driving wise between the two and does it really warrant the extra £2.5k for the 177 model. Are the engines the same block but with a different MAP on the ECU? Is one mechanically more desirable than the other (fault/repair/maintenance wise not BHP)
    Cheers guys
  2. Re: Buying - A5 Cab 150 v 177
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    I think things like turbo and injectors might be different. Mechanically? Both sound units and apart from the power the big difference is mpg. I get between 47 - 52, missus consistently gets 60 plus.
  3. Re: Buying - A5 Cab 150 v 177
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Prety sure the 177 will have a bigger turbo so will take longer to spool up.
    If you are doing a lot of town work, which I imagine you do if a cab, the 150 will give better pick-up & almost certainly better MPG.
  4. Re: Buying - A5 Cab 150 v 177
    Nov 2015
    Sheffield - England
    Well went today to test drive the pair. Unfortunately I didn't even look at the 150 as the 177 literally stole the show
    2015 (15) Audi A5 2.0TDI ( 177ps ) Multitronic Special Edition PLUS | eBay
    I
    think it's an "exclusive" colour as I've never seen an A5 with such a heavy metallic finish to it
  1. Question Buying my first A4 avant 2.0tdi, what spec to get and what to look out for when buying?
    By jakm15 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2016, 09:03 PM
  2. Looking at buying a 3.0 tdi A6.
    By OVI82 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-04-2014, 07:56 PM
  3. Please Help Buying next A8
    By Lenb in forum A8 - S8 - V8
    Last Post: 05-11-2012, 08:08 AM
  4. Please Help Buying TDI
    By Randos in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2010, 05:35 PM
  5. New Guy.... need some help with buying S3
    By humz in forum New Member Introductions
    Last Post: 15-09-2007, 05:09 AM
