Thread: Wiring
  1. Wiring
    May 2015
    Southampton
    Looking to fit a power socket in the rear of the centre console,
    Can anyone tell me if there are any wires running beneath it
    that are only live when the ignition is on ?
  2. Re: Wiring
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Are you looking to allow high current devices to plug in? If so you'd ideally find a 2.5mm wire to help avoid popping the fuse if someone plugs a cup-heater in.
    If you just need a couple of USB sockets for example then I'd fit something that gives you that, and can run off a smaller wire without adding significant load.
  3. Re: Wiring
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Do you have any services in the centre console like external auto connector modules? Or heating / motors in seats? Looking up wiring that is known to be there may be easier.
    There should be a socket in the boot fed by a red+grey 2.5mm wire which probably runs down right of vehicle from fuse 26. Finding that and tapping into it to run under carpets may be best bet. Or down the console tunnel to the front 12V socket making sure you don't foul the gear stick movement.
  1. wiring help please
    By mightymackem in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-01-2017, 02:00 PM
  2. Halogen to Bi-Xenon wiring adapter wiring diagram - might be useful for someone
    By kerbdog in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-07-2016, 06:14 PM
  3. Replies: 0
    Last Post: 18-02-2012, 08:06 PM
  4. Drl wiring
    By beso in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-11-2010, 09:17 PM
  5. Wiring
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-03-2008, 02:22 AM
