Thread: 2008 1.9tdi bxe stalling
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 58
  1. Re: 2008 1.9tdi bxe stalling
    #11
    May 2020
    Pontyclun
    It is possible the line 30 relay in the engine bay fuse box, control group number 100, is faulty
    Thanks for the help, i'll get another from tps tomorrow.
  2. Re: 2008 1.9tdi bxe stalling
    #12
    May 2020
    Somerset
    Thanks both for the info, I think ill spend the afternoon swapping relays with another mk5 I have and testing fuses. I'm sure iv read about water ingress problems and corroded fuseboxs etc, any chance that's a possibility too?
  3. Re: 2008 1.9tdi bxe stalling
    #13
    1836 Post(s)
    This should be what yours looks like
  4. Re: 2008 1.9tdi bxe stalling
    #14
    May 2020
    Pontyclun
    the 100 relay has now been superceded. Original part number was 7mo 951 253 a.
    It is now a 644 relay, part number 4ho 951 253.
  5. Re: 2008 1.9tdi bxe stalling
    #15
    May 2020
    Somerset
    Swapped the relay over, still the same. If i crank for long enough full throttle it will start but then dies straight away. Again, I get those same fault codes...
  6. Re: 2008 1.9tdi bxe stalling
    #16
    1836 Post(s)
    Quote Originally Posted by dean.st View Post
    So you have a dual 100 relay e box?
  7. Re: 2008 1.9tdi bxe stalling
    #17
    May 2020
    Somerset
    No i have just one 100 relay, swapped it for a known working relay I have in another mk5 and symptoms are the same..
  8. Re: 2008 1.9tdi bxe stalling
    #18
    May 2020
    Somerset
    The fault code for fuel pump relay goes when i clear it, if I then exit the engine module on vcds and go back in it reappears without trying to start the car. the rest return after trying to crank it. Which relay is fuel pump on ?
  9. Re: 2008 1.9tdi bxe stalling
    #19
    May 2020
    Pontyclun
    No difference in mine. I only have 1 relay in the box under the bonnet. Still starts after a few cranks and idles fine. Then dies a short while into driving it. No limp mode just dies.
    No noises, no idle issues, no knocks bangs smoke fizzling clicking. nothing!!
  10. Re: 2008 1.9tdi bxe stalling
    #20
    May 2020
    Somerset
    I cant hear any relays click on mine, still got the fuel relay fault code. If i had a wiring diagram I'd attempt some testing but I'm not sure where to start! If I knew which relay was fuel relay and what pins did what id try bypass it see if the pump fired up but I don't know whats what..
  1. 1.9tdi P0726 engine stalling
    By bobslow7 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-12-2014, 09:14 PM
  2. 1.9tdi tiptronic stalling
    By smithy602179 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-08-2013, 09:34 AM
  3. 1.9TDI cutting out/stalling on start up?
    By daviemac11 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2010, 04:04 PM
  4. a6 1.9tdi has started stalling
    By tone35 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-10-2008, 05:33 PM
  5. A4 1.9TDi 130 SE automatic stalling
    By bluetomb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-04-2008, 12:41 PM
