Thread: Dashboard lights out & 'light malfunction' warning on
  1. Dashboard lights out & 'light malfunction' warning on
    May 2020
    Skipton
    Anyone know the secrets of the A5 electrical system? I can't identify a fuse for dashboard lights, likewise front fog/driving lights and sidelight appear to be out. Main and dipped beam OK, indicators OK.
    I assume it's something more complicated than a simple fuse...
    I can see there is a 'Control Unit for Instrument Cluster' listed in the handbook on the brown fuse cluster, but there are also several other 'Control Unit for vehicles electrical system' listed as well. Is there anyway of diagnosing things further or is it a matter of switching stuff out?
    William
    2008 1.8TFSI
  2. Re: Dashboard lights out & 'light malfunction' warning on
    1837 Post(s)
    Without checking I can’t be sure but I would suspect there is no fuse and all those lights are controlled by the Body Control Module. Private Message me the REG and I will check at work.
  3. Re: Dashboard lights out & 'light malfunction' warning on
    1837 Post(s)
    The illumination setting from the headlight switch goes to the J519 BCM which then sends an output on a grey/blue wire to all the consumers such as dash, cig lighter illumination, switch illumination etc so are all the out as well?
  4. Re: Dashboard lights out & 'light malfunction' warning on
    May 2020
    Skipton
    Thanks Crasher,
    Odd. Cig Lighter illum on, switch illum on headight switch is out, neither front or rear fog light switches illuminate.
    Cig Lighter stays on whether ignition on/off and headlight switch on off/side/auto/on. Dash and headlight switch illum out on all combinations.
    I'll check all wiring into the back of the headlight switch.
    William
  5. Re: Dashboard lights out & 'light malfunction' warning on
    May 2020
    Skipton
    Finally got around to doing this, no sign of any probems with connector. On taking the switch out and removing the front cover I've realised all the LED illumination on the switch setting positions are out, so I'm suspecting its a faulty switch.
    10.6.20 : Update to close this off: Faulty switch. Very easy change, remove side/fuse panel, pop out switch, ony one 4 pin connector to remove, pop back in.
    Thanks to Crasher for his response.
    A shout out if I may for Motors in Motion who despatched a repacement switch sourced via ebay. DHL next day delivery.
    William
  1. Please Help Lights Malfunction warning
    By patomlin76 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 09-12-2020, 02:07 PM
  2. Dashboard warning lights don't
    By filbaker in forum Golf MK3 - 1993 - 1999
    Last Post: 10-07-2019, 12:35 PM
  3. A8 Parking Brake Malfunction Warning Light
    By HIWEX in forum VCDS - Help Requests
    Last Post: 21-12-2010, 12:06 PM
  4. Question LT 35 dashboard warning lights.
    By richarda in forum The Commercial Range
    Last Post: 05-02-2010, 04:06 PM
  5. Dashboard Warning Lights
    By shane9new in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-06-2008, 09:47 PM
