Thread: Turbo and Engine problem - oil goes from the oil pan towards intercooler
Results 11 to 20 of 21
  1. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #11
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    It may be worth thinking a bit harder about your original turbo ptoblem. Something in engine may have failed and landed debris in turbo's oil feed / bearing causing it to snap. The something might have been a bit of piston ring?
    Did you clean out oil lines and filters, and find anything?
  2. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #12
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by eusoeu View Post
    Here are my plugs after runing the engine for 5 or 7 seconds. Rough idle and when I give it gas it wants to stall. Any Ideas?Attachment 36933
    Difficult to say for 2 reasons. First the glow plugs and electrical connectors on a Pumpe Duse engine are constantly immersed in oil and it is difficult to remove them without some oil coating them somewhere as they are withdrawn from the oily head. Secondly after a turbo failure debris may be present in places it should not be or has been ingested into the engine in different ways. Any problem involving a mechanical shear failure and the oil or fuel systems means that each should be cleaned through thoroughly. There is also a possibility of cross contamination of fuel and oil systems and this could happen in the cylinders, as a result of a failed head gasket or internal failure within the tandem fuel pump driven by the camshaft. There is also the fact that PD engines eat oil constantly in small amounts due to the crankcase venting system feeding excess pressure back into the pre turbo intake. It does not take long for oil vapours to condense in the intercooler system and oil to be forced into the intake, where it is burned as part of the normal combustion cycle. I am assuming ALL filters are new and the intercooler replaced or the original flushed through completely. As VAG Abound states piston ring wear could attribute to the oil being present and 260k is a fair mileage for the original rings to be at.
    Mad Mitch
  3. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #13
    May 2020
    Toulouse - France
    Thank you so much. Although on the 1.9 tdi bxe engine the glow plugs are not immersed in oil like the 2 litter tdi.
  4. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #14
    May 2020
    Toulouse - France
    I have ordered a compression tester. Will post results as soon as I know. If I find that theres damage inside I probably will order a second hand engine from Germany.
  5. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #15
    Jan 2012
    10 Post(s)
    87 Post(s)
    Of course, I had forgotten that yours is a 1.9 not a 2.0
    Mad Mitch
  6. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #16
    May 2020
    Toulouse - France
    So after a compression test here are the numbers:
    1 = 24
    2 = 28
    3 = 28
    4 = 15 bar
    My book says compression should be 25 to 31 and minimum 19.
    Max Difference between pistons should be 5.
    So I have a big problem with piston number 4.
    I am going to remove camshaft first to see if there's any damage first there.
  7. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #17
    May 2020
    Toulouse - France
    So I had hydrolock my engine when the turbo broke down. Oil whent into cylinder number 4 through exhaust manifold and my connecting rod got bent.
    Obviously as they run in pairs I changed number 1 rod also.
    A very hard job as I done it on my parking lot with the engine (main block) in the car.
    A hard job but interesting.
    All this whilst doing Immunotherapy and radiotherapy for a lung cancer at 51 years old and after 6 months of chemotherapy.
    I am very proud.
    A fantastic job.
    0 3 0
  8. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #18
    Jan 2012
    10 Post(s)
    87 Post(s)
    And so you should be as that is a seriously good achievement with what else you have going on right now. I'm sure you feel the same way as I did the first time I swapped out a balance shaft, put the car back together, and started it up to hear the beautifully smooth sound of a correctly running engine. I did this also on my drive, in the cold and dark finishing at 2am as I needed the car for work that day. It is a very good feeling!
    Well done you sir!
    0 3 0
  9. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #19
    Nov 2016
    Ireland
    14 Post(s)
    Fair play for doing it yourself in the parking lot and for updating the thread. Well done
  10. Re: Turbo and Engine problem - oil goes from the oil pan towards intercooler
    #20
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    Yes an impressive thing to do, how did you remove the connecting rod from the engine as I'm sure they are fitted from the top through, did you remove the crankshaft?
  1. Oil in my intercooler and turbo pipes
    By a4orté in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-04-2011, 11:00 PM
  2. Question turbo/intercooler pipes
    By Pudding1969 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-04-2010, 10:01 PM
  3. Problem with intercooler & turbo help needed
    By audia4134 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-12-2009, 03:59 PM
  4. 1.8t engine or turbo problem
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2009, 12:45 PM
  5. Turbo, EGR and Intercooler maintenance
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-07-2007, 11:19 AM
