Thread: 2014 Audi A6 Avant - Manifold Pressure Sensor Help
  1. 2014 Audi A6 Avant - Manifold Pressure Sensor Help
    May 2020
    Clydebank
    Hi All.
    Just signed up after trolling the net, this forum for days, i cannot find the answer i'm looking for on my own.
    14 plate A6 2.0d - S line black edition has developed a limp mode status, with the engine and coil light on, TPMS was on now cleared, Start/stop function unavailable, so i took it to a mate with Vagcom, un clearable error on the Manifold pressure sensor i assume this to be the MAP sensor, however i cannot find the location of this sensor in the engine bay, searching the net provides nothing for this model as far as i can see.
    Happy to dig around in the engine bay but was hoping for a step for a hint in which corner to look.
    Any body know where this sensor may be?
    Cheers all.
  2. Re: 2014 Audi A6 Avant - Manifold Pressure Sensor Help
    May 2020
    Edinburgh Scotland
    mj, A bit late probably but I encountered exactly the same fault. If you still need help then indicate. For others... The MAP looks like a black lozenge and is on a metal bracket just right of the engine centreline at rear of engine near scuttle in a slightly elevated position. The sensor has been updated by VAG ( now coded '.......K' IIRC - I can check if needed ). It cost approx £62 new from VAG ( quickest place to buy the updated sensor I found ) which is a disgrace for MEMS pressure sensor costing a few bob to make. I then had A DPF error... I now have that and an engine overheating problem. I am now less than enamoured with Audi as they are a pig to work on, information is sparse, spare parts cost a fortune and they are a King's ransom to put to the dealership for what are trivial problems.
    BTW...A MAP can be easily tested using a safety pin as a back-of-connector probe with a multimeter probing the pressure signal pin.... The 3 pins are GND, PWR ( 5v ? ) and SIGNAL and if the latter does not move full range +/- 5V (?) as you press accelerator then that confirms MAP is a dud. Watch multimeter screen through car windscreen under raised bonnet !!
  1. Fault 00575 - Manifold Pressure Sensor
    By BadgerBoy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-09-2014, 07:12 AM
  2. 2001 130 1.9tdi 17564 - Manifold Pressure Sensor (G71)
    By dale_jw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2011, 10:59 PM
  3. Manifold Pressure Sensor
    By hotdog73 in forum VCDS - Help Requests
    Last Post: 07-09-2009, 11:48 AM
  4. Please Help Manifold Pressure Sensor !!!
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 10-03-2009, 03:40 PM
  5. Manifold Pressure Sensor (G71)
    By Stevebt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2008, 02:12 PM
