Thread: No doors except drivers door will open, even using the internal door handle.
  1. No doors except drivers door will open, even using the internal door handle.
    May 2020
    Whitby, North Yorkshire
    Audi A6 ALLROAD 2002.
    The central locking has stopped working. I can get into the drivers door using the key, but when I start the car it doesn’t unlock any other doors. Tried using the lock/unlock buttons and these have no effect. I can’t even the open the doors using the internal handles...
    Any suggestion greatly appreciated.
    Regards
    Richard
  2. Re: No doors except drivers door will open, even using the internal door handle.
    108 Post(s)
    1816 Post(s)
    Water damage to the central incontinence [sic] unit and/or wring under the passengers floor covering. Do the windows work?
  3. Re: No doors except drivers door will open, even using the internal door handle.
    May 2020
    Thanks for the reply. I did have some water in the front footwell from a blocked drain.
    Yes, all the electric windows work.
    If I fit a replacement SIC will this need coding to the cars ECU?
  4. Re: No doors except drivers door will open, even using the internal door handle.
    Sep 2016
    12 Post(s)
    I read this a while ago as it described exactly what mine was doing.
    Mine definitely not flooded, look after plenum drains religiously, absolutely no damp under floor.
    But it was still this unit as indicated by crasher in that black box. Took it out, inspected it and it had "verdigree" ( green corrosion) on a few of it's pins of the multi pin plugs to board edge. Sprayed electronic contact cleaner into female plug sockets and cycled them by mounting and unmounting a few times. Resited all the plugs and tested, all working ok again.
    You'd have to look closely into the detached plug sockets to see it as it's very mild green, but there nevertheless.
    Hope this adds to crasher's good advice in what to look for if anyone else looks in here.
  5. Re: No doors except drivers door will open, even using the internal door handle.
    Mar 2016
    Minervois, France
    53 Post(s)
    Instead of spraying the connector and exercising it, you can remove individual pins and clean them properly, or replace them, using the appropriate one of these.
    59pcs terminal removal tool electrical wiring crimp connector pin extractor kit automobiles terminal repair hand tools Sale - Banggood.com
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  1. Driver door handle wont open door broken ....pulley rod....help !
    By Sam James in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-04-2019, 01:10 PM
  2. Please Help Interior door handle doesnt open the front door
    By stephenwhite990 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2012, 07:09 PM
  3. Question Drivers door handle / opening door
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2010, 08:19 PM
  4. Drivers Internal Door Panel
    By PETER G in forum Chat - Anything with wheels
    Last Post: 07-01-2009, 02:08 PM
  5. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
