Thread: allroad Brake Pressure Sensor.
  1. allroad Brake Pressure Sensor.
    Jun 2019
    Swindon
    Hi guys,
    I don't stop in here much but I have an issue and thought I'd seek a wider audience.
    A little while a go I had the Brake Pressure Sensor fault come up on my C5 allroad but only after a warm restart. As this sensor is built in to the ABS pump on allroads I bought a refurbished pump and module from BBA Reman and swapped them over but the strange thing is the module didn't fault as being from a different car and I didn't tell them my trans and brakes for it to have been coded in advance.
    The sensor issue didn't show itself for a little while but it has returned and again only comes up after a warm restart.
    I've done a full brake bleed to make sure that is all clean and good but I'm starting to think the problem is further down the line and it's actually the ECU that can't see the sensor, rather than it being faulty.
    Have any of you had a similar experience?
    Many thanks
    Mick
  2. Re: allroad Brake Pressure Sensor.
    1841 Post(s)
    I gave up on any type of remanufactured controller years ago, BBA didn’t go bust for no reason...
  1. G201 Brake Pressure Sensor
    By allan_audi in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-05-2020, 09:26 PM
  2. Brake servo pressure sensor
    By macp in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-05-2014, 10:57 PM
  3. Brake pressure sensor fault
    By if11677 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-11-2010, 12:49 PM
  4. Question esp - brake pressure sensor
    By stumpjumper in forum Leon
    Last Post: 23-10-2009, 10:10 AM
  5. Please Help Brake switch and brake pressure sensor issue??
    By P.M.G in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 06:20 PM
