Thread: ATF replace frequency
  1. ATF replace frequency
    May 2007
    Our 53 plate 1.6 auto (01M four speed) Golf has recently gone over the 60K miles mark, and the service docs say check the auto fluid levels. But I can't find a definitive view on when it should be replaced. Also, I'm not clear on whether there is a filter fitted to this box.
    Thoughts? - my instinct is even if the ATF doesn't degrade much, it has been sloshing around in there for nearly 17 years and replacement might not be a bad thing.
    Thanks!
  2. Re: ATF replace frequency
    1836 Post(s)
    Not only the ATF but also the diff oil. The filter is behind the sump plate.
  3. Re: ATF replace frequency
    May 2007
    Thanks once again Crasher. Will sort final drive oil too.
  1. No AM radio frequency
    By mism in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-10-2010, 08:20 AM
  2. How do I find Key Fob Frequency
    By charlyfrog in forum VCDS - General Questions
    Last Post: 08-06-2009, 11:53 PM
  3. using a ipod through radio frequency?
    By strikey in forum Audi A3 - Archive Topics
    Last Post: 18-02-2009, 02:28 PM
  4. Key fob frequency
    By blodnob in forum Audi A3 - Archive Topics
    Last Post: 20-11-2008, 03:25 PM
  5. Fob Frequency
    By korgscrew in forum Archive posts
    Last Post: 05-02-2007, 01:01 AM
