Thread: A4 Cab B6 - Rear Roof Hatch Locked On One Side
  1. A4 Cab B6 - Rear Roof Hatch Locked On One Side
    May 2020
    Surrey UK
    Hi all - as per the subject of the post I have a fault with my A4 cab roof.
    Basically when I try to open the roof either manually or electronically the rear roof cover won't open on the passenger side.
    It lifts up one side when I turn either the key manually in the rear ski hatch or when I open the roof roof electronically.
    All I can think is the latch on one side has frozen up. I'm no mechanic but comfortable taking bits off the car to fix it.
    Does anyone have any knowledge of this issue or any pointers on what trim etc I would need to remove to access the locked latch?
    Given I can't lift the rear hatch at all I can only access it via the boot or via removing the rear seats. Unless I can remove the plastic trim off the rear hatch.
    Any help would be most appreciated!
  2. Re: A4 Cab B6 - Rear Roof Hatch Locked On One Side
    May 2020
    Surrey UK
    Commenting back on my own thread to help anyone out who may have the same issue and they come across this thread.
    Turned out the metal arm that connects the two latches had disconnected, it just needed popping back on to fix it.....
    In more detail; I pulled the trim back in the boot that covers the back side of the rear set and realised the metal arm that connects the two latches had popped off.
    Therefore until I popped the arm back on when I manually went to open the rear roof lid via the ski hatch with the key, when I turned the key the latch on the drivers side latch opened and the lever moved to open the other latch, however as it wasn't connected the latch failed to open.
    I incorrectly thought the passengers side rear latch was stuck......
    1 1 0
  1. 06 A4 Cabriolet stuck roof - Locked on one side
    By rain3000 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-05-2020, 07:53 AM
  2. Rear near-side door locked...and won't unlock!
    By rplc1976 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-07-2013, 08:27 AM
  3. Near side rear door is locked and won't open from inside or out...
    By reeseyboy in forum Golf MK5 - 2004 - 2009
    Last Post: 22-12-2011, 05:40 PM
  4. Drivers side rear door locked
    By Fettler in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-04-2008, 10:33 AM
  5. locked rear drivers side passenger door
    By marcj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 07:51 PM
