Thread: Audi A6 2009 AMI part number!
  1. Audi A6 2009 AMI part number!
    May 2020
    Albania
    Hi. I have an AUDI A6 2009 (C6 4F) Facelift that does not have AMI!. I read here:
    https://a6retrofits.com/ami-retrofit...terface-a6-4f/
    That you can just replace the CD changer unit with the AMI with part no. 4E0 035 785 B and it will automatically work. Is this true?
    My other question is that I have only found 4E0 035 785 D part (not B). Will that work as well?
    Thank you!
  2. Re: Audi A6 2009 AMI part number!
    Jul 2013
    76 Post(s)
    For the facelift A6 with 3G MMI you only need to add a cable into the MMI unit.
    You need to active it in the hidden green menu.
    https://www.kufatec.com/en/car-hifi/...r-mmi-3g-36735
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Audi A6 2009 AMI part number!
    May 2020
    Albania
    Quote Originally Posted by dan2485 View Post
    Hi Dan, thanks for your message. So, replacing an AMI unit won't work? I just ask this because I found it quite cheap from an A4 2009, for only like $75.
    Otherwise, would this cable allow me to have AUX output at least? 1pcs/lot High Quality MMI 3G Music interface AMI AUX Phone Pod cable For Audi Q5 A6L A4L Q7 A5 S5 music interface line|Power Cords & Extension Cords| - AliExpress
    I only say this because the link you sent me, although it might work great, it is a bit over my budget and I cannot spend that much right now.
    Thank you for your help!
  1. Replies: 5
    Last Post: 30-01-2020, 01:29 PM
  2. Replies: 13
    Last Post: 21-02-2014, 06:04 PM
  3. Question Audi Concert Part Number For B6 A4?
    By jimmer.c in forum In Car Entertainment
    Last Post: 11-05-2010, 10:19 AM
  4. audi part number's
    By big jase in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-01-2010, 10:26 PM
  5. Audi Cam Sensor Part Number
    By mgouldstone in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2008, 08:50 AM
