Thread: i need new coil springs
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. Re: i need new coil springs
    #21
    Mar 2016
    Minervois, France
    53 Post(s)
    johnro79.
    Did you make sure the wheels were on the ground, with the suspension and shock absorbers in the normal, loaded, position before you tightened all the nuts and bolts passing through bonded rubber connections?
    The bonded rubber bushes can only be rotated to a certain extent, so the bolted connections though them should only be tightened with the wheels on the ground. Otherwise they will be subjected to increased torsional stress, there will be increased resistance to their movement, making the suspension feel harder, and their service life will be severely shortened.
    There should be ample warnings about this in the repair manual you are using.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  2. Re: i need new coil springs
    #22
    Apr 2016
    London/UK
    23 Post(s)
    Quote Originally Posted by FrenchAudi View Post
    johnro79.
    thanks for your input on this.
    my suspension is normal, nothing self adjusting (air or electronic one)
    does this apply to me too? i've seen a lot of posts regarding this for fancy suspensions , nothing for the one i've got.
    thanks again
    EDIT: a nice video i found explaining what's what with suspension loading and tightening : YouTube
  3. Re: i need new coil springs
    #23
    Mar 2016
    Minervois, France
    53 Post(s)
    It applies to all cars, not just Audis, which have bonded rubber bushes in the suspension. Which is probably all cars made after about 1960
  4. Re: i need new coil springs
    #24
    Apr 2016
    London/UK
    23 Post(s)
    After weeks of going back and forth, this is what I have as a replacement choice.
    Now looking to see if they're ok for my car
  5. Re: i need new coil springs
    #25
    1836 Post(s)
    Using your VIN they are the correct part numbers BUT ETKA doesn't call it "FI suggestion" for nothing so it would be nice of the colour codes are still there on the originals to cross check.
  6. Re: i need new coil springs
    #26
    Apr 2016
    London/UK
    23 Post(s)
    from a post you've done on the 1st page, i have an extra white dot on the rear ones
    old ones are long gone and can't crosscheck
  7. Re: i need new coil springs
    #27
    1836 Post(s)
    8K0 511 115 HA should be 1 x green, 1x grey and 3 x white
  8. Re: i need new coil springs
    #28
    Apr 2016
    London/UK
    23 Post(s)
    got me worried there. that's what i've got.
    i'm booked for next thursday to have them replaced.
    hope they'll stretch the shock to give them a little travel distance. right now it feels like shocks are being compressed to the max
    fingers crossed
  9. Re: i need new coil springs
    #29
    1836 Post(s)
    I would go armed with at least rear bump stops, they take a right beating.
  10. Re: i need new coil springs
    #30
    Apr 2016
    London/UK
    23 Post(s)
    Wow. What an improvement. Having the right coils on a car stops it from wobbling with the road
    Now, having driven the car for 2 months leaning on shocks only and hitting every dent, I'm worried I've damaged the shocks. Car still wobbles firmly left and right, shorter distances now with good new springs, but when I go over small humps 1-3 inches , even at low speeds, it feels like a hard impact instead of a smooth ride over them
    Besides a push and bounce and a visual leakage test, how else could I test them now?
    Been drivin the car 2-3 months with these shocks and bad springs and now for about 3 days with the same shocks and new springs
  1. Question Coil springs
    By maccaone in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-07-2015, 03:29 PM
  2. Question 1.9 tdi coil springs
    By switchblade in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2011, 06:30 PM
  3. coil springs
    By shaunebabe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-11-2008, 08:13 PM
  4. Question front coil springs
    By robertb5714 in forum New Member Introductions
    Last Post: 05-09-2008, 09:31 AM
  5. coil springs
    By panther in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2007, 06:10 PM
