Thread: i need new coil springs
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
  1. Re: i need new coil springs
    Apr 2016
    London/UK
    23 Post(s)
    The front springs are Pr 0JG so 8K0 411 105 EC (Suplex 03259) @ £129.78 Audi retail with 1 x violet and 2 x orange marks and the rears are Pr 0YJ so 8K0 511 115 HA (Suplex 03274) with 1x green, 1 x grey and 2 x white marks @ £129.07 Audi retail. The car has factory 1BE sports suspension
    Any chance you could pls help me with shock codes too pls? WAUZZZ4G6EN078816
    Somehow somewhere smtg went wrong. After replacing shocks and springs now my suspension has no travel, it's very rigid. stick-like.
    All the absorption I have it's mostly done by the tyres. car (as in whole body) is riding all the shapes of the road.
    Right now these is what I have on:
    Bilstein
    19226903
    Sachs 313366 814902002958 30 h 55 a
    i also renewed these:
    lower suspension wishbone arms
    are these arms also different for normal/s-line or all those 3 types of suspension that audi has?
    Thanks for your help
  2. Re: i need new coil springs
    108 Post(s)
    1816 Post(s)
    The genuine front dampers are 4G0 413 031 C and originally would have been Monroe and would be the Bilstein 19-226903 you quote, Sachs do not list it.
    A Sachs 313366 replaces 8F0 513 035 J, 8T0 513 035 G, 8F0 513 035 D, 8K0 513 035 AT, 8T0 513 035 M, 8F0 513 035 N, 8F0 513 035 M, 8F0 513 035 E, 8T0 513 035 AB and 4G5 513 035 D
    Which springs did you fit?
    What are the make and part number of the arms you used?
  3. Re: i need new coil springs
    Apr 2016
    London/UK
    23 Post(s)
    thanks a lot. i need a lot of help with all these as it doesn't make any sense to me.
    work has been done in 2 parts: arms and absorbers at first and then coils .
    the reason i've done coils is that after replacing arms and shocks the car was solid and bouncier too. hence i thought springs were an issue . after replacing springs nothing else has changed, so i didn't needed them anyway (i only have warehouse codes i guess 627445340 and 627446860. i believe they are sachs if that means anything to you guys )
    as for the arms, i've never worried about them as i thought they can't be different types, just brands. i believe they are lemforder. i will enquire asap.
    so from what you are saying, shocks would've worked with my old springs, as they are a close like4like oem replacement?
    thanks again
  4. Re: i need new coil springs
    108 Post(s)
    1816 Post(s)
    So you have fitted new genuine VAG springs all round?
  5. Re: i need new coil springs
    Apr 2016
    London/UK
    23 Post(s)
    no, sorry
    1st job was fitting
    Bilstein 19226903
    lower suspension wishbone arms left+right
    after that, suspension was very solid/rigid and unstable at 30-40-50 mph. nothing was absorbed
    then i thought springs were abused and overused and ive changed them too.
    i only have these codes 627445340 and 627446860. i believe they are sachs if that means anything to you guys
    it's not the case. suspension is still rigid, car doesn't absorb any shocks whatsoever. when i drive, car vibrates up and down with the shape of the road and all passengers are bounced side to side when road uneven .
    done wheel alignment at 2 centres . both times they were within the limits
  6. Re: i need new coil springs
    108 Post(s)
    1816 Post(s)
    The dampers are typical of many companies in being a one fits many short cut but the do cross reference correctly, the rears are even more generic but still cross reference OK so I can't see it being the dampers themselves. 627445340 is the ECP number for a Sachs front spring BUT against VAG number 8K0 411 105 EC Sachs don't list a spring... I had this earlier today with ECP, a customer from London came up to have us fit a clutch in his Golf 5 GTI; he had bought ECP supplied dampers and springs by Sachs to do himself but did not enjoy doing one side so asked us to finish the job but I thought I would check the parts first, the dampers were fine but the springs hopelessly wrong. Whenever I buy anything from them I cross reference the manufactures number back to try and avoid **** ups, it doesn't always work! The ONLY aftermarket producer of OE spec springs I trust is Suplex but at the moment their springs are hard to get hold of and so I would suggest what I have done with the Golf 5 here, order genuine springs.
  7. Re: i need new coil springs
    #17
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    In that Sachs catalogue I linked above it has 8K0 411 105 EC matching their part 993 132. Pops up on here as well: Search for 8K0411105EC - 11 results - onlinecarparts.co.uk.
    Whether that is what ECP supplied is another question. OP - if you look closely there should be some yellow or white print on the spring that has that number. A mirror or phone camera might help .
  8. Re: i need new coil springs
    #18
    Apr 2016
    London/UK
    23 Post(s)
    Quote Originally Posted by VAG-Abound View Post
    thanks for this
    i had bad/rigid suspension after i fitted the shocks and also before getting springs replaced too.
    as soon as there's daylight i'll try and find a curb to mount and take a looksie
    just saw that the above 993132 is not recommended for s-line
  9. Re: i need new coil springs
    #19
    Apr 2016
    London/UK
    23 Post(s)
    could you pls tell me the genuine part number for the lower suspension wishbone arms left and right please. I really wanna check those too.
    i think those , if they were wrong, they would not have fit. would they?
    from what i understood so far, the front dampers , bilstein 9-226903, is a correct part. i'll stick with that.
    front sachs springs are not good as sachs does not have listed anything compatible with my car oem part number.
    i can't link the springs and dampers i have on the rear with the car's oem part number as i can't identify the spring details. dampers do fit
    geez luise. at least i know where to start now. thanks a lot for your time
  10. Re: i need new coil springs
    #20
    108 Post(s)
    1816 Post(s)
    8K0 407 151 F control arm left front £109.78
    8K0 407 152 F control arm right front £109.78
    4G0 407 693 L wishbone link left front £198.83
    4G0 407 694 L wishbone link right front £198.83
    Audi retail + VAT
  1. Question Coil springs
    By maccaone in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-07-2015, 03:29 PM
  2. Question 1.9 tdi coil springs
    By switchblade in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2011, 06:30 PM
  3. coil springs
    By shaunebabe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-11-2008, 08:13 PM
  4. Question front coil springs
    By robertb5714 in forum New Member Introductions
    Last Post: 05-09-2008, 09:31 AM
  5. coil springs
    By panther in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2007, 06:10 PM
